Old 11-17-2016, 07:52 PM   #1
Converter charger location
Looking for converter charger location on my 2016 Cardinal 3850
Fireguy7542 is offline   Reply With Quote
Old 11-17-2016, 08:24 PM   #2
Left Coast
Normally they're right behind the breaker/fuse panel.......Need to remove panel cover, then the breaker assmy.....the wires stay attached..
Old 11-26-2016, 09:56 PM   #3
jacknife's Avatar
My Cardinal convertor is in the basement right behind a vented panel
jacknife is offline   Reply With Quote
Old 08-30-2017, 07:55 AM   #4
I did get any ligature with my 3850 on converter. Would like to know what brand and type to look up owners manual
Old 08-30-2017, 12:40 PM   #5
Pretty sure its one of these, but you'd have to pull the bulkhead and get eye's on to know for sure.
PD9270 - 70 Amp RV Converter/Charger - Progressive Dynamics
Dave
2017 Cardinal 3850RL Mocha Pearl full body paint
2016 F350 Lariat 4x4 FX4 SRW CC SB 6.7 Magnetic Metallic
djousma is online now   Reply With Quote
Old 09-02-2017, 05:21 PM   #6
Converter
I have a 2015 Cardinal 3850 and have replaced the converter twice. This is my third one. Mine was behind the fuse panel. The only way to get to it was remove the basement panel and crawl over water and heater hoses.
Progressive Dynamics 9245 RV Converter 45 Amp
xomkid is offline   Reply With Quote
Old 09-03-2017, 10:17 AM   #7
don't know the floorplan of your cardinal. I have a 3825. I found the converter behind a bulkhead wall in the basement storage compartment. look for an access panel on the bulkhead wall. there is one by the water center on the drivers side to access water fittings. there is one on the passenger side to access the converter. ours is a PD 9270 (70 amp). of course yours may be different based upon the floorplan.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
CHICKDOE is offline   Reply With Quote
cat, converter, location
