Old 01-12-2014, 11:48 AM   #1
Converter Location on 2013 Cardinal 3450RL
Does anyone know the location of the 70 Amp Converter in the 2013 3450RL?
Butch
HappyKampers is offline   Reply With Quote
Old 01-12-2014, 12:01 PM   #2
BigTJohn's Avatar
Should be (probably not) in the 12vdc fuse panel/120vac breaker box insert. Usually it hides in the lower right part. You should (may see) a green light either steady, fast flashing or slow flashing.
Brenda and John
Master Blaster of the Navy
BigTJohn is offline   Reply With Quote
Old 04-06-2014, 03:43 PM   #3
Somewhat right of center
Crabbyguy's Avatar
What does the fast flashing mean?
2014 Crusader 260RLD Champagne Touring Edition
2013 Silverado 2500 6.0 HD
Crabbyguy is offline   Reply With Quote
Old 04-07-2014, 07:37 AM   #4
BigTJohn's Avatar
Flash speed shows how many amps are being returned to the battery and being used by the 12 vdc system. Fast is max charge, slow is med charge, steady is trickle/maintenance charge. There is a small black button which can change the charge rate. It will switch back to auto when needed.
Brenda and John
Old 04-07-2014, 07:41 AM   #5
Crabbyguy's Avatar
Thanks. I have to keep an eye on it. It always seems to be fast flashing. Looks like I'll have to break the male rule and look at the owners manual.
Old 04-11-2014, 08:25 AM   #6
Cardinal/Blue Ridge Rep.
The Converter should be under the steps. In the pass through storage bay, the carpeted wall to the rear of the trailer is held in with 4 screws. If you remove this wall you should be able to access the power converter.
ssobkowiak is offline   Reply With Quote
Old 04-11-2014, 09:05 AM   #7
Crabbyguy's Avatar
After reading the manual, fast flashing means the battery is 50% to 90% charged and slow flashing means it's below 50%. Little different.
2013, cardinal, cat, converter, location
