Old 06-22-2016, 07:33 PM   #11
wayne nichols's Avatar
I am with Gottoys. My 2008 Cardinal 30RKLE looked a little off so I brought it to the local big rig trailer place. My rear right side axle was off about 1/2" they fixed it in about 45 minutes they have the equipment to jack up the whole camper off the wheels. They replaced what needed and they even re-bent my springs to get the correct curve back. When they lifted the camper they found one spring that didnt hang the same as the others about 2" difference.
Leah, Wayne & Max
2008 Ford F-450 King Ranch 4X4 6.4L
2008 Cardinal 30LE
wayne nichols is offline   Reply With Quote
Old 06-22-2016, 11:59 PM   #12
Hi Wayne, thank you for the feedback.
I've noticed that the left rear and right front are wearing even but left front and right rear are rounded on other edges and think there is a bent axle or some kind of damage causing the tires to wear that way.
Thank again
Doug, aka Wanderer
2008 Cardinal 30RK fiver.
2009 Chevrolet 2500HD DuroMax
2009- 42 days; 2010-40 days, 2011- 40 days. 2012- 30 days,
2013- 14 days, 2014- 21 days, 2015- 42 days
2016-17 days, 2017-zero days
Wanderer is offline   Reply With Quote
Old 06-23-2016, 05:16 PM   #13
wbdavey's Avatar
Doug - I replaced the bushings and bolts with 'wet bolt" kit from Dexter on 2 previous 5th wheels. The first one had less than 10,000 miles and the bushings were shot - found while correcting the camber on one axle. A truck spring place did the first trailer (2 axles) for about $500 - had to remove both axles and the equilizer to do the job. The second one I replaced during the first year to prevent the problem before it happened. I did the second one myself in the driveway - 3 axles, 2 sets of equilizers. A lot of hammering and jacking and heavy cribbing and a long day for 2 old guys. My advice is buy the kit and have a spring shop do the work.
2015 Rockwood Ultra Lite 2604 WS. Rear LR, large street side slide with small wardrobe slide in BR.
2014 Ram 1500 Eco Diesel Laramie Quad Cab.
wbdavey is offline   Reply With Quote
