Old 01-04-2016, 02:52 AM   #1
Dexter Heavy Duty Suspenion Kit
In Sep 2015 issue of Trailer Life, they discuss this suspension upgrade due to the factory plastic bushings wearing out rapidly. The new kit uses bronze bushings. Just curious if anyone here has done this. (We have 2008 Cardinal fiver)
Anyone know if in fact the Cardinal did use plastic bushings?
One of the reasons I'm considering this is that I have noticed the space between the tires is different between the left and right sides by about one inch or more? Normal, I would guess not.
Any feedback whatsoever would be appreciated.
Douglas aka Wanderer
2008 Cardinal 30RK fiver.
2009 Chevrolet 2500HD DuroMax
2009- 42 days; 2010-40 days, 2011- 40 days. 2012- 30 days,
2013- 14 days, 2014- 21 days, 2015- 42 days
2016-17 days, 2017-zero days
Wanderer is offline   Reply With Quote
Old 01-04-2016, 01:33 PM   #2
HONDAMAN174's Avatar
Don't know if this will help but it is what I did:
TT suspension upgrade
2014 Evo 2850 "Woodstock"
2011 Toyota Tundra "Clifford"
Just glad to get away
Old 01-04-2016, 09:28 PM   #3
My guess is one of your axles may be out of alignment. Are your tires wearing normally? I would get under the unit and measure the distance between the axles on each side.
Rich5117 is offline   Reply With Quote
Old 01-04-2016, 11:27 PM   #4
Hi Rich, Put about 8K miles on new tires last year. One has a more rounded wear pattern but not extreme. TT is in storage now. Will retrieve soon for planned trips. Will measure at that time. Was wondering if this bushing/equalizer might be part of alignment variance.
Thank you.
Old 01-05-2016, 08:27 AM   #5
I wouldn't think for the extreme differences you have. All of your bushings on one side would have to be toast and your axle would shift we you hit brakes.
Old 01-05-2016, 12:34 PM   #6
jacknife's Avatar
I changed out my suspension to a moryde 4000 also changed the shackles . The shackles are much heavier and come with wet bolts. When swapping out the shackle bolts had plastic inserts. Mine is a 2013, 30-30
jacknife is offline   Reply With Quote
Old 01-05-2016, 01:47 PM   #7
Check shackles for wear. They are a weak link. Had one set fail at 30K. Others not far behind. Had all replaced. Spring guy said poor steel quality and marginal design.
Harkerr is offline   Reply With Quote
Old 01-05-2016, 06:20 PM   #8
Also don't think the bushing would allow that much movement. The ends where each spring attaches to the RV is a fixed point. The axles attaches to the spring and is usually positioned by a small pin which sets into the axle from the spring. If one of these broke or a shackle is loose it could let the axle shift. Most axle sets come with the springs already positioned and attached. I had to replace both axles last year because of the no longer made sealed wheel bearings. Please let us know how you make out. Axles, springs, and tires is something we all check.
Old 01-07-2016, 10:52 PM   #9
Bring it to a big rig suspension shop and have the alignment checked. Don't waste your time at an RV dealer, they don't have the knowledge or equipment to do a proper alignment. About $200.00 and everything will be straight. They can install those bushings and new shackles too.
2015 Chev Silverado 3500 dually D/A
2016 Cedar Creek 36CK
B&W Patriot 18K, Trail-Aire pinbox,
Level up, dual panes & all that stuff...
GOTTOYS is offline   Reply With Quote
Old 03-01-2016, 06:24 PM   #10
One response to my OP suggested an alignment center specializing in RV's about an hour from me (Redlands) in Southern California. Now I cannot find that post. So I am requesting info on that if anyone has a good experience with frame/axle alignment facility.
Thank You.
