Old 08-26-2015, 11:05 AM   #1
did i just find a rear view camera cable?
2015 cardinal model 3825 - it has a black box on up top on the rear that i was told is for a rear view camera. i haven't worried about it as all the posts say a wireless camera will not work well and to put a wired camera in would mean running a cable all through the trailer (at least 40 feet to get to the front). a couple of days ago i had to get into the from storage bay (the generator bay) and way in the back corner i found a coil of cable with an rca type plug on it. so this is not an electrical cable. is it a video cable from the rear camera housing? (if not what is it?) if it is a video cable from the rear camera has anybody actually installed a rear view camera using this cable? what type? could i mount the antenna inside the generator bay and would it work with a wireless monitor in the truck? that is only about 25 feet. again what camera / monitor did you use? does it work? where did you mount the antenna? thanks for letting me pick you brains.
CHICKDOE is offline   Reply With Quote
Old 08-27-2015, 12:31 PM   #2
Jestercyco's Avatar
We have a 3800FL Cardinal. In my storage bay are 2 cables coiled up for the TV we are going to put in. It also has a 110 volt single plug, also for the TV. You might check for that set up.
Jester
2012 Super Crew 4WD 6.7 PSD
2015 Cardinal 3800 FL
2007 Road King Black Cherry-Hers
2007 Road King Blue-Mine
1979 FXS Hot Rod Shovelhead
Jestercyco is offline   Reply With Quote
Old 10-13-2015, 12:25 PM   #3
I have a 40 foot 5 th wheel and have put a wireless camera in the rear works just fine with no problems. I have a Furrion backup camera high resolution camera. The mounts are being installed on Forest River Products
swannie is offline   Reply With Quote
