08-28-2018, 04:16 PM
Enjoying our ride!
Dinette table movable?
Hi - Can someone tell me if the dinette table in our Cardinal 3250rlx 2018 fifth wheel can be adjusted to move or is it bolted to the floor permanently?
Sandra
08-29-2018, 08:26 AM
I would recommend that you look under the table if it had just a pedestal more then likely its bolted and won't move if not it may be like mine with two legs that can be moved
Retired Navy
2016 Flagstaff 26 FKWS
08-29-2018, 09:29 AM
If you have a standard dinette it should be removable and bed into a bed.
If the connection on the floor ( pyramid shaped) matches won under the top than yes, it is removable.
Some also have a folding leg. I have never heard of a nonremovable table. but that doesn't mean there aren't any.
08-29-2018, 09:40 AM
x2 on the previous. Mine is a pedestal and is bolted to the floor. I guess it could be unbolted. Not sure why you want to do this. I've thought about removing it and putting in a dinette type with storage under the seats. Better use of space too.
Happy trails and safe travels
'17 Coachmen Chaparral
'17 Silverado 6.6L Duramax
Retired & Full Timer
KI4OVB
08-29-2018, 03:49 PM
Enjoying our ride!
Thanks to everyone I just thought it would be nice to move around to adjust for company. Mine is a pedestal and bolted down.
Happy travels hope everyone has a great labor day weekend. Pismo Beach here we come!
Sandra & Robert
2018 Cardinal 3250 RLX 5th Wheel Trailer
2015 GMC 2500HD Denali
B & W Goose neck Hitch in the Bed
Blue Ox Super Ride 20K hitch
08-29-2018, 06:10 PM
Sandra
Looking at pics of your model on the Forest River/Cardinal web site, it looks like the "feet" of the table are screwed to the floor. You could remove these screws to make the table movable. However, it must then be resecured to the floor before travel. And don't loose or substitute the screws....they are of the proper length so as to hold the table to the floor without going completely through the floor. If the screws were to protrude through the floor, they would cause damage to the bottom seal and floor inside the coach when you brought the slide in.
2014 Prime Time Sanibel 3250
08-29-2018, 07:45 PM
Enjoying our ride!
Thanks for the advise, I guess the table is staying put.....
Happy Labor Day!
Sandra & Robert
08-29-2018, 08:01 PM
On my old fiver the top had a piece of ply wood made to slide the table out by having two aluminum z rails attached to the table so it was able to slide and allow people like me to slide around the table then slide it back into place I suppose you could do that to it.
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
08-29-2018, 10:33 PM
Enjoying our ride!
We can look into that option, there always seems to be a way to make it work if you try.
Sandra & Robert
08-30-2018, 06:22 AM
Happy Labor Day!
My 3850RL table is also screwed to the floor, however the tabletop itself has a latch underneath allowing it to slide out from the wall about 6 inches, so that the folded down leaf's at both ends can be flipped up giving more table top space.
Dave
2017 Cardinal 3850RL Mocha Pearl full body paint
2016 F350 Lariat 4x4 FX4 SRW CC SB 6.7 Magnetic Metallic
08-30-2018, 11:32 AM
Woah!!.......nice feature!
Mine has a regular leaf the goes in the middle, just pull the one side out & insert leaf which is stored nicely in the base of the table.
08-30-2018, 12:01 PM
Enjoying our ride!
That's it! I couldn't figure out why there was a fold out leafs at both ends and the table couldn't move to open both ends. That is very helpful, you made my day!
Thank you-
Sandra & Robert
08-30-2018, 12:13 PM
Thank you-
Your welcome. I think the table top, along with the chair seats lift up for some hidden storage too. I think I remember that, but we dont use it.
Dave
09-02-2018, 07:21 AM
I have a Cedar Creek and the table is screwed to the floor with long screws. I just unscrew the screws and turn the table around. You have to use a number 2 bit, the proper name is a Robinson bit. The number 2 bit is a square bit that fits all the screws in the camper
09-28-2018, 11:28 AM
Well, thanks for that info! My husband and I have been trying to figure out the drop leaf on the window side since the trailer was delivered!
09-28-2018, 11:59 AM
Enjoying our ride!
So glad it helped other figure it out, happy camping!
Sandra & Robert
