Old 07-07-2017, 05:44 PM   #1
Does my 2009 Cardinal have an inverter?
I recently bought a 2009 33RK 5th wheel and love it so far. The previous owner said it has on on-board inverter that delivers power to some of the outlets in the coach. However, I've had no luck finding an outlet with inverted power. Does anyone know if this model came from the factory with an inverter?
Thanks!
Buzzroll is offline   Reply With Quote
Old 07-07-2017, 06:02 PM   #2
Broadway Joe's Avatar
What type refrigerator do you have. Normally they only install an inverter if yours is equipt with a residental 115 vac refrigerator.
Joe
2015 Wildwood 27RKSS
2015 Silverado 2500HD Duramax
Broadway Joe is offline   Reply With Quote
Old 07-07-2017, 06:24 PM   #3
If there is an inverter, you need to find it and turn it on I would think. Can you still contact the previous owner for the location?
Old 07-08-2017, 05:49 AM   #4
Look in the front basement compartment. If there is one, it would be mounted very near the batteries. It has an on/off switch. About the size of a shoebox.
Dave
2017 Cardinal 3850RL Mocha Pearl full body paint
2016 F350 Lariat 4x4 FX4 SRW CC SB 6.7 Magnetic Metallic
djousma is online now   Reply With Quote
Old 07-09-2017, 07:03 PM   #5
Your inverter is the front compartment.mountedon the rear wall right side.also the button to turn it on should be under your main panel.
MikeCNY is offline   Reply With Quote
Old 07-09-2017, 07:17 PM   #6
Oakman's Avatar
Thanks!
No your 2009 Cardinal did not come with an inverter from the factoy. If it has one it was put in by the previous owner. Your unit does have a converter/charger but that is a completely different animal. Trailer manufacturers began putting inverters in the trailer when they began putting in residential style refrigerators.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 07-09-2017, 09:03 PM   #7
I stand corrected . my 2015 cardinal does have an inverter. As I do have a residential fridge with ice ect. Sorry .
cardinal, inverter
