Old 10-12-2015, 02:11 PM   #1
Dump valve handles, which is which?
I have a 2016 Cardinal 3875FB (first time out) and am confused as to which dump valve handles are which.
OK, I know black from gray but I have two large handles outside the unit. The front one is bronze colored and the rearmost one is gray. Inside the storage area are a small black and a small gray. There are two pipes and I cannot figure which is black and which is gray? Anyone with the same setup, can you shed some light on this dilemma and an idea of which is which?
snormaniii is offline   Reply With Quote
Old 10-12-2015, 02:31 PM   #2
bubbles's Avatar
Typically, where the two come into a single outlet the one with the smaller pipe is gray water.
Old 10-13-2015, 12:07 PM   #3
bigdaddy1
bigdaddy1's Avatar
I feel your pain..I have a 2016 3850RL Cardinal that has two grey handles and one black on the pulls for the drains. I had to just pull one and go to the lights and see if it was tank that I thought it would be. Looks like a simple label from the factory would keep us from guessing. Well, I really needed the exercise anyway so of well...
BigDaddy1
2015 F350 CC Lariat 4/4 SRW
6.7 diesel
bigdaddy1 is offline   Reply With Quote
Old 10-14-2015, 09:58 AM   #4
OK, I discovered the bronze handle is actually black with gold overspray on it😂
The Normans
2014 Chevrolet 3500HD
Old 10-14-2015, 10:03 AM   #5
Georgia Frog Rally 2018
aceinspp's Avatar
I just add a label from my Brothers labeler just for good measures. Manufactures getting lazy. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days camped in 2016 58
Days camped 2017 62
Days camped 2018 18
Old 10-14-2015, 01:29 PM   #6
I discovered that the gray line was hooked up to the black water tank, and the black water tank was hooked up the the gray water discharge. I was only able to empty the black water tank after having driven a couple hundred miles because that allowed the contents to be broken up.
This is on a 2015 F3 motor home.
S_richmond54 is offline   Reply With Quote
Old 10-14-2015, 01:41 PM   #7
Sloopoke
You can't always go by the color of the handles or the labels. My new Salem Hemisphere Lite has the front grey tank and the black tank mislabeled. I found that out when I thought I was draining the grey tank in my yard the first time. Not pleasant. I have learned that the large pipe will mostly be the black tank and the smaller pipes feeding into it will be grey tanks, no matter how it is labeled.
sloopoke is offline   Reply With Quote
Old 10-15-2015, 08:50 AM   #8
The pipes are all the same size. I found the best way to discover which was which was by adding a clear fitting. Now I know which valve is black and gray. You need a clear fitting anyway so you can tell when your black tank is empty and clean.
Jim
07 Dodge 1500 crew cab with 20" wheels, 08 Forest River Rockwood Signature Ultra-lite 8280SS
"The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man."
George Bernard Shaw
oldtool2 is offline   Reply With Quote
Old 10-15-2015, 04:43 PM   #9
Cardinal 2015
3875 has black handle near front for front bath black water and gray handle for baths gray water I was told. Small black handle in compartment for half bath only. Gray handle in compartment is for galley (kitchen gray water). By utilizing 2 short hoses and a Y fitting all can be emptied with out disconnecting thru your sewer hose.
CRG3875FB is offline   Reply With Quote
Old 10-15-2015, 05:50 PM   #10
Originally Posted by oldtool2 View Post
............. I found the best way to discover which was which was by adding a clear fitting. Now I know which valve is black and gray. You need a clear fitting anyway so you can tell when your black tank is empty and clean.Jim
This, and black water is dark brown with lumps, kitchen is lighter brown and bath is nearly clear, unless you're a really dirty person .
phillyg is offline   Reply With Quote
