Old 12-13-2010, 10:16 AM   #1
Traveler II's Avatar
Electric Heat
This might be a good addition for those that use your RV a lot. It cost a bit, but I can see that it would be a connivence. It is a add-on electric heater which attaches between the propane furnace and the ducts, controlled by the existing thermostat. The add-on provides the heat when the unit is switched to electric. So no propane use except for cooking, and hot water. It is not available to private parties, RV dealers only.
CheapHeat
Jim and Jane
2008 Cardinal 30TS
Trail Air Pin Box, Center Point Suspension
Reese 18K hitch - Garmin 1690 GPS
2008 Chevy 2500HD 4x4 Duramax/Allison, Long Box, Smartair
Nights camped in 2011: 120
Traveler II is offline   Reply With Quote
Old 12-13-2010, 10:30 AM   #2
Wanna Be Camper
SaskCampers's Avatar
It seems like a good idea, although some of their reasoning is out there.
John & Deb
2011 Flagstaff V-Lite 30WRLS
Old 12-13-2010, 10:50 AM   #3
$850.00 plus dealer mark-up, plus 5 hours installation equals a lot of propane IMHO.
...VTX-AL
VTX Al is offline   Reply With Quote
Old 12-13-2010, 02:35 PM   #4
I agree it would cover the cost of a lot of propane, but still if you use your RV lots it might be a nice addition. I'm thinking about it, we use ours 3-5 months each year.
Jim and Jane
2008 Cardinal 30TS
Old 12-13-2010, 03:51 PM   #5
Send a message via Skype™ to scubieman
I think I would consider a space heater. Another issue I can see is you probably will for sure be using at LEAST 1500 watts. Will your current electricity system work? Plus I have been kinda sold on those Eden Pure. Which cost about 297 dollars and heat up to 1500 sq ft.
scubieman is offline   Reply With Quote
Old 12-13-2010, 09:15 PM   #6
Herk7769's Avatar
I installed Envi High-Efficiency Whole Room Electric Panel Heater - White (Model # HH1000) - eheat.com in the master bedroom on the wall. It provides PLENTY of heat in the almost UNHEATED area above the kingpin.
It pulls only 450 watts at full power and is one of the best improvements we made to the camper.
HAM CALLSIGN - KC3FFW
Old 12-14-2010, 07:38 AM   #7
WestCoastRV'er's Avatar
The Envi looks great. Going to order one for our rv bedroom.
2011 2902ss Rockwood Ultralight
2008 Grand Cherokee 3.0L Diesel (255 hp @ 2900 rpm / 430 lb-ft @ 1,400-2,800 rpm)
3P ProPride Hitch
RV Mods
Wandering RV Life
WestCoastRV'er is offline   Reply With Quote
Old 12-14-2010, 08:04 AM   #8
We use a small portable space heater, and usually on the lowest setting. We put it down in the living area out of the way, and the heat just naturally rises into the bedroom. Inexpensive and effective.
Old 12-14-2010, 08:40 AM   #9
Herk7769's Avatar
We never realized the shortcoming of the heat distribution in our floorplan until we had guests stay in the living room. When we closed the hall curtain and the pocket door to the bathroom, there were NO heat registers in the bedroom (one in the hall floor and one in the bathroom floor).
While our guests were overly warm and toasty with the propane heat and the electric fireplace heater, we froze our butts off. Problem since solved with the Envi heater (at least on full hookups anyway). We may have to limit our "dry camping" friends to VERY close friends only.
cardinal
