Old 05-04-2018, 05:39 PM   #1
Electrical Power issue
I was cleaning my fantastic fan and discovered that even with all power disconnected (batteries and shore) I still had power to the fan. Does the inverter/charger hold a reserve?
Broncl is offline   Reply With Quote
Old 05-04-2018, 05:42 PM   #2
I do have to ask ... how long did it run?
2016 RAM 3500 DRW 4x4 LB LoneStar Edition, w/Timbrens, Andersen Ultimate 2, Swift Hitch SH04 WiFi Backup/Rear View Camera
2018 Chaparral 360IBL w/Tireminder SMART TPMS, Furrion Wireless Observation System, Progressive EMS-HW50C
2006 RAM 3500 DRW LoneStar Edition
2011 Starcraft 392BHU w/Andersen No-Sway hitch
chaps2018 is offline   Reply With Quote
Old 05-04-2018, 05:49 PM   #3
Lacey's Spring, AL
formerFR's Avatar
nope.
is the fan wired directly to the batteries, or are you sure that you 'disconnected' the house batteries(or was it the 'chassis' battery, by chance)
formerFR is offline   Reply With Quote
Old 05-04-2018, 06:18 PM   #4
Electrical power issue
Thanks for responding,
It ran for 20 or more minutes until I pulled the fuse.
I was totally disconnected from everything, in fact I removed all the wiring from the batteries and double checked to make sure that I was not on shore power.
There has to be power coming from somewhere.
By the way it is a 5th wheel with dual batteries but they were totally disconnected.
Old 05-04-2018, 06:24 PM   #5
fonzie's Avatar
Well start looking for another battery somewhere, did you buy this unit used from someone else? or were you still connected to your truck?
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
Old 05-04-2018, 08:15 PM   #6
cavie's Avatar
I have to ask. Are you plugged into your TV?
2011 Keystone Sprinter 323BHS
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 05-04-2018, 08:38 PM   #7
PPST Wannabe
kenandterry's Avatar
Wow!!!!!
A fantastic fan that runs without a power supply.
Elon Musk is good....but even he ain't that good.
This could open up a whole new market for boondocking.....they’re always looking for ways to be off the grid.
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is offline   Reply With Quote
Old 05-04-2018, 08:46 PM   #8
Who said perpetual motion is a myth?
(I'm betting TV is plugged in.)
2011 Traverse LT, 3.6L, FWD
Old 05-04-2018, 10:41 PM   #9
electrical power issue
OK I am willing to take the bet on being plugged into the tow rig. It was at least 20' away so not likely any power from there. The 5er is just sitting in the driveway with no shore power and the batteries are totally disconnected.
One other idea that came to mind as I was trying to figure this out is that there is a solar battery charger but wouldn't that power have to go through the battery before going to the fan?
I bought this trailer new to answer one of the questions. If I figure it out maybe I can sell a patent to Tesla.
Old 05-04-2018, 10:51 PM   #10
OK, I've lost (another) bet.
Now that you've mentioned solar, I'm guessing that all the wires to the battery are still connected together, but just not landed on the battery lugs. So your solar is supplying the rig through the connected wires.
Remember that your battery can be both a power supply and a load. When it's charging, either from the converter or the solar panels, it's simply a load. When you disconnect it, the converter can still supply your 12VDC circuits. So if the solar is still connected to the wiring to the battery, even if the battery is no longer there, it is still supplying the 12VDC circuits.
If you aren't familiar with RV electrical systems, check out all the links that Site Team member wmtire has put together in Post #16 here:
Struggling with Electrical Knowledge
He's got a lot of other good links for water heaters, propane, etc., too.
Old 05-05-2018, 12:08 AM   #11
It sounds like the solar is powering your fan. It doesn’t go “through” the battery. Think of the solar as another battery connected to your 12 volt and ground wires.
2017 Rockwood 2703WS - Sold
2015 Keystone Sprinter 333FWFLS
2017 F250, 6.2 Gas, 3.73 Axle, 2902 lb Payload
If women don't find you handsome, at least they should find you handy!
andymil is offline   Reply With Quote
Old 05-05-2018, 01:42 PM   #12
Thanks everyone!
Never hurts to learn something new so I will check out the suggestions. And, I will think about solar as another battery rather than as a battery charger or maybe both ways.
Thanks again for your responses,
electric, electrical, power
