Old 03-18-2017, 10:32 AM   #1
Fireplace
Brand new Cardinal, 3950tz. Fireplace is flashing 88 and no heat coming out. Continues to flash when turned off. Can't lower temp setting. And so it begins....anybody know of a fix?
Dylanfreak is offline   Reply With Quote
Old 03-18-2017, 10:46 AM   #2
SeaDog's Avatar
I don't know the unit but try securing the power to the unit via a circuit breaker with the unit off and see if that resets it, this is just a guess on my part
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 03-18-2017, 11:38 AM   #3
SeaDog's Avatar
I forgot to mention what ever you find that fixes the problem let the forum know so we can all learn from your experience
Retired Navy
Old 03-18-2017, 12:46 PM   #4
Just as confused as you
Scrapper's Avatar
Problem: "The display unit on the control panel shows “88” and the function
indicator is quick flashing, indicating it is in alarm mode."
Solution: Unplug the unit from the wall outlet for 5 minutes. After 5 minutes plug the unit back into the wall outlet, and operate as normal.
If this doesn't work then try 10 minutes. Depending on the brand.
Does yours look like this? http://www.homedepot.com/catalog/pdf...3469f5ed69.pdf
Richard & Jill
Camping since 1989, seasonal since 2000
The Faster I Go, The Behinder I Get.
