Old 10-15-2015, 05:13 PM   #1
Cardinal 2015
Fresh water tank drain
I am new to RVing and can not locate the fresh water tank drain on my new 2015 Cardinal 3875FB. Can anyone point me to the correct spot. Online manuel states open drain valve but doesn't give a clue as to where it is located.
CRG3875FB is offline   Reply With Quote
Old 10-15-2015, 07:32 PM   #2
On Cedar Creek the fresh water tank valve is on the tube at the bottom of the tank( under the rv). It's realistically the only place gravity can empty the tank which is necessary to winterize it. Look around, it's there 👍
SilverbackMel is offline   Reply With Quote
Old 10-17-2015, 09:36 AM   #3
Major's Avatar
Our Blue Ridge (made by Cardinal) has a single "blue" tube extending from beneath the underside cover near the rear of the unit. It had a plug in it so I removed it and screwed a elbow into the female coupling and extended a pipe to the rear bumper with a valve on it.
Now I don't have to get under the thing any more to drain the fresh water tank (we do a lot of "dry camping" so we have to take the water with us).
Doug and Becky Ridgeway
2014 Blue Ridge 3600RS
2014 Ford F-350 CC 4X4 DRW 6.7 PSD
Troy, NC
Major is offline   Reply With Quote
Old 10-18-2015, 11:28 AM   #4
Cardinal 2015
Got it, thank you for the help.
drain, fresh water, tank, water, water tank
