Old 05-20-2015, 09:48 AM   #1
Front jacks, one in-op?
2008 Cardinal, 30RK. Yesterday setting up here in Asheville, NC, the drivers side jack had to lift the fiver, the drive mechanism is turning to op side but d that jack is not extending? So, wondering if this is a quick fix or a major repair issue?
Thanks for feedback,
Wanderer
2008 Cardinal 30RK fiver.
2009 Chevrolet 2500HD DuroMax
2009- 42 days; 2010-40 days, 2011- 40 days. 2012- 30 days,
2013- 14 days, 2014- 21 days, 2015- 42 days
2016-17 days, 2017-zero days
Wanderer is offline   Reply With Quote
Old 05-20-2015, 09:56 AM   #2
Ford Idaho's Avatar
Broken bolt on the cross over pipe/tube?
With the front storage door open does it turn?
Old 05-20-2015, 10:02 AM   #3
The bolt is loose, but the shaft is turning. Will have to verify the inner part of pipe/ube is not slipping.
Thankst
Old 05-21-2015, 09:09 PM   #4
Thankst
UPDATE: The bolt was broken and 3/4 of had fallen to the floor of storage compartment. Got new bolt and nut, installed, now it seems the drive motor only wants to retract; when you try to extend, it rachets or doesn't rotate at all????
So with this update in mind, what is the Cardinal readers consensus/suggestions?
Is it possible the drive motor is failed/failing??
Thanks for suggestions,
Wanderer
Old 05-22-2015, 03:20 PM   #5
Had to take mine apart in Whitehorse cause of the same problem. The jack has to be taken out of its mount and disassembled. On the top of the screw shaft there is of hole that holds a cross pin. When the cross pin becomes bent it slips in the indented washer which is the ratcheting sound you here. The pin needs to be replaced. It's a good time to lube the internal works while you at it. If it's a Lippert jack their web site had a schematic of the jack and its internal parts.
tyke8319 is offline   Reply With Quote
Old 05-23-2015, 10:14 AM   #6
Thank you for feedback, that is exactly what the problem was, my ignorance of the way this system operates cost me $800.00 yesterday, this for RV service to park where were having the service guys jack up unit so we could hitchcup then at the service center, they first pulled the motor transmission. It was ok but dry as a bone. after that they pulled the passenger side leg and that roll pin had in fact broken. all in all it was an expensive learning experience.
Wanderer
Old 05-23-2015, 10:19 AM   #7
Ford Idaho's Avatar
Wanderer
Wow!
Anyway glad it is working now, travel safe.
Old 05-23-2015, 11:56 AM   #8
FYI, if you do have Lippert jacks it is much easier and CHEAPER to call Lippert and buy a new jack (if that works for you). When my second jack went out I took that one apart and found several parts rather warn out. Called Lippert and I think the new jack was around $300 and took 20 minutes to install and rewire. Boy, is that one quieter....
jacks
