Old 03-13-2014, 07:12 PM   #1
Sg6923's Avatar
Furniture trim peeling
Any ideas as to what would cause approximately 5" of the dresser corner to peel? Both corners are peeling as well as one corner on the bed. It's been under roof all winter. 3625 RT YR 2010.
T-Man
Sg6923 is offline   Reply With Quote
Old 03-14-2014, 03:56 PM   #2
Cardinal/Blue Ridge Rep.
Could you attach a picture to the post?
ssobkowiak is offline   Reply With Quote
Old 03-14-2014, 03:58 PM   #3
Sg6923's Avatar
I will and upload tomorrow. Thanks!
Old 03-15-2014, 02:07 PM   #4
Sg6923's Avatar
Here is a picture of the peeling. It extends about 6" up from floor. When not camping its in covered storage.
Name:	ImageUploadedByForest River Forums1394910382.098233.jpg
ID:	47762Click image for larger version
Name:	ImageUploadedByForest River Forums1394910420.040469.jpg
ID:	47763Click image for larger version
Name:	ImageUploadedByForest River Forums1394910458.830281.jpg
Old 03-15-2014, 02:22 PM   #5
Rrickim63's Avatar
Strange..i would replace with real wood...
Sent from my LG-LS720 using Forest River Forums mobile app
2006 Roo 23B hybrid
2006 Ford F150 4.6L
Rrickim63 is online now   Reply With Quote
Old 03-15-2014, 02:23 PM   #6
Sg6923's Avatar
Not a bad idea. I'll look into it. Thanks!
Old 03-16-2014, 10:09 PM   #7
I would suspect that moisture got to it making it expand. Was it high humidity where it was stored?
Sent from my SCH-I545 using Forest River Forums mobile app
2007 GMC 2500 Duramax Crew Cab LB
2008 5th Wheel Cardinal 36LE
R Whitlow is offline   Reply With Quote
Old 03-17-2014, 08:27 AM   #8
It looks as though moisture got into the trim and made the trim expand. Is your storage area climate controlled?
Old 04-07-2014, 06:08 AM   #9
Sg6923's Avatar
No it is not temperature controlled. I had the trim replaced. I do have moisture rocks in the BR but in the closet. I'll be adding a fresh supply. Thanks Forum!!
Old 05-31-2014, 06:59 PM   #10
Sg6923's Avatar
Just an update. I replaced the trim and bought a bucket of moisture absorber. Don't anticipate any further issues.
