Old 10-08-2011, 12:42 PM   #1
Gary0848's Avatar
Send a message via AIM to Gary0848
GFI proublem!
Hi fellow RV'ers! I have a Cardinal 3602bH 2010. Ever since I have had it the GFIs have to be reset often. There are 3 in all and the is no logical reason to kick out. Often nothing is being used. Is it just crapy units or what are your thoughts?
Gary0848 is offline   Reply With Quote
Old 10-08-2011, 12:46 PM   #2
DAISY BOYKIN's Avatar
I had the same problem !
You may have one or more bad GFI's, that was my problem. One bad GFI out of three.
Good Luck
Sid, Lois & HRH MISSY Terrible 3s SHIH TZU
2011 ROCKWOOD 8285 WS
2014 F-250 KING RANCH PS 6.7L/SWD/6R140/BFT
DAYS CAMPED 2018 60 DAYS
DAISY BOYKIN is offline   Reply With Quote
Old 10-08-2011, 12:47 PM   #3
Lottery Non-Winner
Ovair's Avatar
I'd remove each one and check behind them to make sure all connections are tight.
2011 Georgetown 337
2009 HD FLHTCU
2007 HD FXSTC
Ovair is offline   Reply With Quote
Old 10-08-2011, 12:51 PM   #4
Gary0848's Avatar
I will give that a try first. Thanks for the feedback.
Old 10-08-2011, 01:28 PM   #5
You might also want to check to be sure there is only one GFCI per circuit. Any more than that and you will guaranteed have problems.
Old 10-13-2011, 10:47 AM   #6
Gary,
I have a 2010 3625 and the dealer replaced all 3. He said FR had some bad switches and told them to change any and all.
Big bird is offline   Reply With Quote
Old 10-13-2011, 04:14 PM   #7
Gary0848's Avatar
Originally Posted by Big bird
Gary,
Big Bird,
Thanks for.the reply. I will just replace them as.they are fairly cheap.
