Old 09-13-2017, 07:01 PM   #1
Grey tank showing full when its empty
My Gray tank indicator is reading full and it was just emptied? where to start?
LCWarden is offline   Reply With Quote
Old 09-13-2017, 07:28 PM   #2
bubbles's Avatar
If it was indicating full when you emptied it give it some time for the residual water to dissipate. Then again, maybe there is an issue.
Old 09-13-2017, 07:48 PM   #3
Oaklevel's Avatar
First step ignore the lights and learn when your tanks are full by experience .......
Sorry the indicator lights are poor at best and commonly mess up. Crud gets on the sensors... Some one l be along for help. I personally am from the days before the indicator lights came out and just ignore them..
Or d you have another dump handle maybe behind a wheel ??
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Old 09-13-2017, 08:55 PM   #4
Nature of the beast
If not camping, I am Sailing
JohnVtx is offline   Reply With Quote
Old 09-13-2017, 09:01 PM   #5
"On the road again"
rjshiflet's Avatar
Send a message via AIM to rjshiflet
Soap suds/scum can cause a false reading long after it is emptied. You'll learn just by experience to be a better judge than the indicator can ever be.
Robert & Estha Shiflet
Cardinal 3456RLX - '17 Ford F350 Lariat Ultimate - DRW w/B&W OEM Companion hitch
Nights Camping 2012 & 2013 & 2014 & 2015 & 2016 & 2017 & 2018: 834 ~ Nights Camping 2019: 97
rjshiflet is offline   Reply With Quote
Old 09-13-2017, 09:43 PM   #6
SilverbackMel's Avatar
Circular argument. End result: experience will be your guide.
Gauges sometime work or not.
Mine unit is on sewer hook up for months at a time. Valves closed except to DUMP and back rinse.
Always black first; both gray, then sprayer system. Last time it showed "full" black; 5 people used it another week. Never got anywhere close to full.
Cheap; unreliable gauges.
SilverbackMel is offline   Reply With Quote
Old 09-15-2017, 04:21 PM   #7
jacknife's Avatar
Don't spend much time worrying about it
I empty mine , it will read empty a gal of water later it shows full.
jacknife is offline   Reply With Quote
show, tank
