Old 04-05-2018, 07:21 AM   #1
racindirt06's Avatar
Heat pump
Went to use heat pump today and is only blowing cold air, I made sure the fan was in auto before turning on. Any suggestions?
racindirt06 is offline   Reply With Quote
Old 04-05-2018, 07:41 AM   #2
It will not work below 45 degrees
If not camping, I am Sailing
JohnVtx is offline   Reply With Quote
Old 04-05-2018, 08:07 AM   #3
cavie's Avatar
You haven't stated where you are. I'm gonna guess it's cold. Everyone has their own version of "It won't work below XX degrees" The more accurate degrees is 35 F. There are some that will work lower but not on most RV's. The Heat Pump is nothing more than your AC running in reverse. Blowing hot air inside and cold air outside. If the outside temp is below 35 it cannot transfer the heat. Time for your furnace of an electric heater.
2011 Keystone Sprinter 323BHS
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 04-05-2018, 08:27 AM   #4
Nice of you cavie to know that 35 is more accurate. Mine will not keep temp below 45 regardless of what you think is a better number.
Old 04-05-2018, 08:33 AM   #5
Mr. Dan's Avatar
cavie, what is your sample size for your definitive comment "on most RVs"?
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 86; booked = 0
Old 04-05-2018, 08:52 AM   #6
cavie's Avatar
Industry standard design. You will never get 5 people to determine what the temp is. The answers you get will be " Mine Does" or "mine Doesn't". The design standard is ABOUT 35 degrees. Your results may vary. If I had one that didn't work below 45 degrees as stated above it would be laying in somebody's junkyard.
Old 04-05-2018, 09:44 AM   #7
Mr. Dan's Avatar
Heat pump
Design standard? For RV heat pumps? Really? I thought RV components had their own unique “undesign”. Ha!
Old 04-05-2018, 09:46 AM   #8
I’m in Hagerstown MD, temp was about 50 but wind was blowing 15-20mph. I didn’t know about the under 35 or 45 temp.
Old 04-05-2018, 06:53 PM   #9
Heat pump should have worked fine. I would turn breaker off for 30 seconds then try again
loyda is offline   Reply With Quote
Old 04-05-2018, 06:56 PM   #10
cavie's Avatar
+2
Old 04-06-2018, 04:54 PM   #11
My rv is 42 ft. Cavie. Are we comparing apples to apples?
pump
