Old 11-28-2018, 10:15 AM   #1
Heatpump
The cruisair freezes up when outside air gets below 40. Is there a device that would switch it to gas furnace when temp drops
loyda is offline   Reply With Quote
Old 12-11-2018, 05:01 PM   #2
Heat pump
On my thermostat I can choose between air, fan, heat pump or furnace. Not sure why no one has replied to you. I don't get on here very often. Most people don't use heat pump below 50 degrees(not very efficient).
grconner1 is offline   Reply With Quote
Old 12-11-2018, 05:16 PM   #3
Ours works good to 40. Would just be nice if it would auto switch to gas furnace when temps drop below 40 degrees. It takes a lot of propane to heat. We stay in our 5th wheel all winter and on our boat other seasons here in Virginia on the Potomac river
Old 12-11-2018, 05:32 PM   #4
Heat Pump
Check with heating and air personnel, I'm sure something is available but it wouldn't be cheap. I take it that your not around to choose between the two?
Old 12-11-2018, 06:57 PM   #5
I think mine are Atwoods. They do automatically switch when they can't hold the temp.
DYNAMAX 2016 FORCE HD
houstonstroker is offline   Reply With Quote
Old 12-30-2018, 11:01 PM   #6
jacknife's Avatar
40 is about it with a,heat pump.
jacknife is offline   Reply With Quote
pump
