Help! 2014 Cable / Antenna Switch
ON EDIT: Solved. Found the answer in a post below. Thanks.
Hi. I'm parked next to a guy this morning with a 2014 front living room Cardinal. He doesn't know how to operate his TV. Is there an LED push button on this model Cardinal to switch from antenna to cable reception? If so, where is it? It's not on the wall panel in the cabinet under the front living room TV.
Thanks from a Cedar Creek owner. On our way home from FROG.
Doug
