Old 03-30-2018, 06:08 PM   #1
racindirt06's Avatar
Help with cable on 17 3825fl
I’m having more issues lol! Just got setup at campground, hooked up cable wire and no cable inside. Did auto scan on all 3 TVs and nothing works. Any suggestions?
racindirt06 is offline   Reply With Quote
Old 03-30-2018, 06:39 PM   #2
Mr. Dan's Avatar
Did you turn OFF the OTA antenna booster/amplifier? Cable won't work with it on.
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 =111/'19 = 86; booked = 0
Old 03-30-2018, 06:40 PM   #3
Yes
Old 03-30-2018, 06:42 PM   #4
Fulltime family RVer
^^^ that first. The booster is usually a small white plate that the cable plugs into. The button has to be “out” and the green light OFF.
The scan for the TV has to be done as “cable” and not antenna.
And lastly, if that doesn’t work- run a cable straight to the back of a TV.
Does that work?
If not, the problem is likely with the campground.
If so, then we can look more at the camper (specifically- connect the cable to the SAT connection(s) and try again).
Old 03-31-2018, 11:34 AM   #5
The Newsoms's Avatar
I had to pull off the panel in the storage compartment to see that the cable line was not even connected.
The Newsoms is offline   Reply With Quote
Old 03-31-2018, 11:43 AM   #6
I checked that also!
Old 03-31-2018, 12:41 PM   #7
My old Cardinal and my brand new Arctic Fox replacement both had the outside connections for satellite and cable reversed. Try the other connector and see what happens.
DrLewie
Flemington, NJ
Former: 2007 Cardinal 30W LE
Now:2018 Arctic Fox 27-5L
2008 Ford F-250 Long Bed Diesel
Total of 30 Months on the Road Since 2008
DrLewie is offline   Reply With Quote
Old 04-01-2018, 04:29 PM   #8
I had to rewire all the Splitters they were hooked up backwards
If not camping, I am Sailing
JohnVtx is offline   Reply With Quote
Old 04-03-2018, 05:57 PM   #9
We had bad connection in the front tv and good connection the rear tv the place I brought it from said that they had hook it up wrong from the factory
DaleS is offline   Reply With Quote
cable
