08-20-2019, 11:33 AM
Help with VIN location!
I recently purchased a 2000 Cardinal 5th wheel from my brother who lives in Illinois. I live in Ohio and in order to get the title in my name the BMV has to match the VIN # from the title to the one on the camper. We can't find the one on the camper anywhere! I have googled and looked everywhere they suggested it could be. What can I do if it has worn off?
08-20-2019, 12:17 PM
Are the stickers on the drivers side towards the front still there an visible, that would be the 1st place to look.
Next would near the pin box.
There could be a sticker inside one of the cabinets inside.
Edit: One other possibility is your brother may be able to get a replacement sticker from forest river.
2024 Artic Wolf 3018 Suite 5th Wheel
Prior TT Grand Design 2800BH TT 2021 - sold 4/24
TV 2024 F350 DRW Lariat Ultimate
Prior TV 2017 F150 6.5' bed 3.5 Eco-boost Max tow 1800lbs payload - sold 4/24
08-20-2019, 12:22 PM
Look along door frame, cabinets, every nook and cranny you can find.
08-20-2019, 12:24 PM
Thank you for responding
There is a white square on the drivers side , I would say a sticker has been there but has either faded off or fallen off. I have also looked in the cabinets
08-20-2019, 12:27 PM
Long shot...given the age, but did you go all around the base of the frame and underneath ? My old 2007 jayco had one down low along the frame that was barely visible.
08-20-2019, 12:51 PM
I believe my VIN was stamped at the poinbox mount on my 5er.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
08-20-2019, 01:05 PM
Just as confused as you
Here is a list of places I have found the VIN number. Most will be on the left/drivers side of the rv.
on the frame near the pin box
on a metal tag welded or riveted to the hitch
steel frame member under the camper body
stamped on a metal section of the frame
on a sticker inside a cabinet door or wall
cargo carrying capacity sticker
Richard & Jill
08-20-2019, 01:21 PM
Mine have always been on the frame near the top of the pin box on the passenger side. The outside stickers nearly always fade out.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
08-20-2019, 01:29 PM
The vin on my Cardinal is written in weld on the pin box mount.
Gary and Donna
2005 Cardinal 33TS-LX
Trail Air pin box
Center Point suspension
2018 Ram Laramie 3500 6'4" box 2WD
Demco AutoSlide 18k
08-21-2019, 05:57 AM
I know my has worn off. It was located on the drivers side of the 5th wheel near the front just below the access door for the front struts. The sticker over the years has completely worn off. Seems it should be more permanent
08-21-2019, 08:01 AM
Check the Closet wall ???
We had a Flagstaff TT all the Info was in the closet !!!
08-21-2019, 03:57 PM
VIN sticker replacement method
My VIN sticker on my 2004 TT was almost gone, too, when having to register it in FL from UT. The officer was able to make it out (barely) and told me to complete an affidavit request for a new sticker with the Department of Motor Vehicles.
I just called and was told I need to present photocopies of all documents listed for that purpose, on the DMV website in my state. i.e. proof of ownership via front and back views of title; Form 84004 (in FL) which is the affidavit request, etc. Once that's turned in , they send it to our state capital to order a new sticker for me. Finally, the postman comeths with the goods.
I'd forgotten about needing to do that! Thanks for the reminder.
suzea
08-21-2019, 04:16 PM
The VIN stickers are the first thing thieves peel away. Each manufacturer stamps a secondary VIN into the frame somewhere.
08-21-2019, 04:26 PM
Yes, my VIN was stamped on top of the triangular frame near the jack and batteries. However, the officer verifying it told me he officially needed to see the sticker. Guess they're afraid anyone could carve a VIN # into a frame.
