Old 09-05-2016, 02:30 PM   #11
Evereddie's Avatar
When you hear it and the fan is off, is it really off? Is this an electronic fan with variable speed? The electronics in the fan can be bad and provide a trickle of power even though you turnned it off. That would account for the noise and battery drain. Pull it's fuse and then listen.
Evereddie is online now   Reply With Quote
Old 09-05-2016, 04:38 PM   #12
I just got home from camping and when packing up today I walked in our camper I heard a high pitched sound. I checked the CO detector and the smoke detector and` that wasn't it but noticed that my fridge had not switched over to propane. I went to check battery knowing the battery had to be charged for the fridge to work on propane. Come to find out I had a loose battery wire. I tightened it went back inside and the fridge was working and the high pitched sound was gone.
Just a thought .
cwalters2112 is online now   Reply With Quote
fan
