Old 07-22-2012, 07:07 PM   #1
Question Leak in lippert hydraulic pump
any info on parts and repair
onedevine1 is offline   Reply With Quote
Old 07-22-2012, 07:26 PM   #2
CLASS "A" Senior Member
cfsoistman's Avatar
Leveling/Stabilization Owners Manuals
Hopefully there's some info to help you on their site under Service.
Welcome to the forum! Hope you find the info you need to take care of your leak.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
Old 07-22-2012, 07:47 PM   #3
Dave_Monica's Avatar
Have you tried the hydraulic pump manufacturer's site for info?
Dave
Old 08-26-2012, 08:30 PM   #4
If it's leaking from the seal in between the pump and the reservoir it probably is the o-ring. You can remove it and take it to a hydraulic shop or Zgraingers and get a replacement.
lakejumper is offline   Reply With Quote
Old 09-11-2012, 12:56 PM   #5
Dallas Texas
TexasBBQ's Avatar
For the slide or leveling system?
2004 Cardinal 33CKT
2006 Ford SDD F250 CC 4WD
TexasBBQ is offline   Reply With Quote
Old 09-11-2012, 03:32 PM   #6
You can do a search at this site and get lots of suggestions. It seems most of the time the leak orginates at the o-ring between the motor and tank. I took out the four bolts, removed the tank, pried out the o-ring, spiral wrapped it with teflon tape and reinstalled. The leak is gone. I have posted this several times.
jdecanter is offline   Reply With Quote
