Old 12-18-2016, 10:47 AM   #1
Lines showing after hosing down coach.
Took delivery last weekend and coach had salt on it, so I hosed it down this morning. It's 55 degrees, after some brutal cold, so I'm hoping the reason I'm seeing some lines, vertical and horizontal, is due to constuction, and condensation. Even if I wipe them clean, they show up, and it looks like they follow where studs might be. Maybe as a result of vacuum bonded walls???? I'm assuming if the weather didn't change so much....? New England...Mass, starting to wonder why I live here. Any thoughts?
Dylanfreak is offline   Reply With Quote
Old 12-18-2016, 10:59 AM   #2
glsimms's Avatar
I can't offer any suggestions, but those lines do look pretty uniform. If this is a new unit, maybe take it to the dealer or show them pics and see what they say. May also want to contact Cardinal as well.
glsimms is offline   Reply With Quote
Old 12-18-2016, 11:04 AM   #3
keith52's Avatar
Those lines are where the "studs" are located. They will disappear as it warms up.
2014 Chevy CC Duramax 4X4 Long Bed
2017 Cedar Creek 36CKTS
MORryde independent suspension with disc brakes
keith52 is offline   Reply With Quote
Old 12-18-2016, 11:06 AM   #4
This. Mine doe the exact same thing.
2001 Ford F250 7.3l converted to F350 specs
2014 Flagstaff 8528RKWS
2006 model year Border Collie
Mtelkman is offline   Reply With Quote
Old 12-18-2016, 11:21 AM   #5
Ford Idaho's Avatar
Same here, the stud will retain the cold longer than the laminated wall.
Old 12-18-2016, 11:32 AM   #6
Good to hear, that it's probably the cold studs. Safe to say in "normal " weather, you don't see this?
Old 12-18-2016, 11:36 AM   #7
keith52's Avatar
You are correct
Old 12-18-2016, 02:14 PM   #8
Talking studs
All RVs do this because of the heat differential between the warm studs and cool outside temps....It would be nice to be able to see the studs on the inside when you want to hang something inside.....
Bob Vaughn is offline   Reply With Quote
Old 12-18-2016, 03:46 PM   #9
jkoenig24
In addition to the pictures, take some measurements of the studs exact location. Should you want to mount something substantial, it will be easier if you know where the studs are.
jkoenig24 is offline   Reply With Quote
Old 12-18-2016, 04:35 PM   #10
Like others have said. Heat difference between studs and outside wall. I have had 4 RV's and all did this in cooler weather.
2015 Flagstaff 26VFKS
TV - 2014 F150 Crew Cab 5.0L
WDH - 1,200 Equalizer
txredfish is offline   Reply With Quote
Old 12-18-2016, 05:07 PM   #11
sfsgm's Avatar
I don't know about the lines but as to why you live there perhaps you like the taxes???
2016 Nike Take Down Wrestling Shoes
42 ft square Dollamur high school wrestling mat
sfsgm is offline   Reply With Quote
Old 12-18-2016, 06:43 PM   #12
Scubanut's Avatar
Absolutely a good idea to take those measurements or even put a small marker at the bottom or/and top to indicate where they are.
2012 F150 FX4 Crew 5.0 3.73 gears
2O12 Coachman Freedom Express 292BHDS (outdoor Kitchen)
Scubanut is offline   Reply With Quote
Old 12-18-2016, 07:13 PM   #13
Really good idea to take the measurements and mark the studs. We do that when building (our house, our children's houses). If you have a high enough resolution camera, just stretch a tape measure across the outside of the unit and photograph it so you can see the measurements and the stud outlines. It is pretty quick and with digital you can blow it up. You may have to do several shots for horizontal and vertical studs, but that, along with a stud finder will get you some pretty good accuracy. Just use a tape with good size numbers on it. We use it inside to mark TV mounting studs, etc when building, before putting up the drywall. It works and really helps.
ProfChuck is offline   Reply With Quote
Old 12-18-2016, 07:49 PM   #14
Same thing on our CC 29RE
I drew up a sketch and marked the distances between from front to back...Use reference points like windows & doors etc Now you know where they are from inside...J
Jim in Halifax is offline   Reply With Quote
Old 12-18-2016, 08:08 PM   #15
john5646's Avatar
First time I saw this I took pictures. For use as reference for stud locations, should I ever need them. Click image for larger version
Name:	ImageUploadedByForest River Forums1482109697.592369.jpg
john5646 is offline   Reply With Quote
Old 12-18-2016, 08:56 PM   #16
SilverbackMel's Avatar
Aluminum studs. Normal in any condensation situation. My 2015 Silverback looks similar.
Go to the next FR factory FROG rally and take the factory tour. You will learn a lot. It's interesting to see frame; walls hung; frame and how and where tanks; heaters; furnace are mounted.
Also, even if you do not need to; at least practice a winterizing. Even if you just do the draining and use air.
There will come a time when you need to do this quickly. Trust me; 30 degrees and wind is no time to LEARN. There is much NOT to miss.
SilverbackMel is offline   Reply With Quote
Old 12-18-2016, 09:54 PM   #17
Stormrider151's Avatar
Mine does this most every morning. Kind of handy if your into modding your trailer.
Retired Fire Dept Battalion Chief
2016 Ever-Lite 232RBS
2012 F150 FX4 W/Max tow & Ecoboost (Best tv ever)
2018 F250 Lariat (ok but I miss my F150)
Getting old ain't for wimps!!!
Stormrider151 is offline   Reply With Quote
Old 12-18-2016, 10:36 PM   #18
glsimms's Avatar
Like the OP, I had no idea what was causing the lines to appear. Now I know, you learn something new everyday....
show
