Old 09-03-2016, 02:59 AM   #1
Question Lock for Screen door?
Anyone else feel need to have a lock on the screen door? Many times we like to have the main door open like in evenings or early mornings but seems somewhat insecure.
2008 Cardinal 30RK fiver.
2009 Chevrolet 2500HD DuroMax
2009- 42 days; 2010-40 days, 2011- 40 days. 2012- 30 days,
2013- 14 days, 2014- 21 days, 2015- 42 days
Wanderer is offline   Reply With Quote
Old 09-03-2016, 04:22 AM   #2
Witch Doctor's Avatar
That's a good question but by how it made I can see no way of doing what you want to, but do understand why you would want to. The problem I see is where it locks to the main door. I'll interested if anyone has done something myself...
Rockwood #8289 WS 2012
F250 6.0 / Husky 16k
With 4 point leveling system
Old 09-03-2016, 09:56 AM   #3
Not sure if I see the benefit of locking the screen door. Even if you could lock it somebody could easily rip the screen out and crawl thru the opening with ease.
You'd be surprised how easy it is to get the main door unlocked. My parents were the first to arrive at the campground yesterday with their Crusader fifth wheel. When we arrived with our Blue Ridge we found that my parents somehow got locked out of their camper. As chance would have it I was able to open their rig with the keys for mine. Even the dealer said that most Forest Rivers are keyed the same if not similar. Lucky for my parents!! Lol
2012 F350 DRW 6.7 PSD
Blue Ridge 3710 BH
garmford is offline   Reply With Quote
Old 11-28-2016, 03:10 PM   #4
"Ten Minute Tech" in Trailer Life Magazine: A subscriber used a window sash lock (one part on the door frame the other on the frame of the door sideways), it wouldn't work on our trailer because the door frame was too narrow as was the frame of the door to secure the sash lock.
I will try to explain what I did. I made two bar locks which consisted of two pieces of flat metal, two open bent clips and a few screws. I screwed one bar into the door frame above the sliding plastic (to get to the door handle) and one underneath the sliding plastic. Both bars were screwed loose enough so the bars could rotate up or down, up to open the door down to "lock" the door. The bent clips were screwed into the trailer door frame (open end up) level with the bars on the door so the bars "dropped" into the clips to bar the door from opening (like the pioneers used to "lock" the cabin door). I also cut a flat piece of metal that fit in the horizontal screen door channel that fit between the rear vertical screen door frame and the closed sliding plastic piece, which prevented the sliding plastic from being opened. Two bars gives a bit more strength to the "lock". If someone really wanted in they would get the door open, but it would stop someone from just opening the door and give you time to react. I used this on a prior trailer that had no windows, just the bedroom door. Another project for the Cardinal.
1010 is offline   Reply With Quote
door, lock
