Old 08-21-2011, 11:03 PM   #1
Smile lug nut torque
Need correct torque for lug nuts on a Cardinal 30WB le with Aluminum wheels. Any help really appreciated.
Alan Fowlkes is offline   Reply With Quote
Old 08-21-2011, 11:42 PM   #2
jimh's Avatar
unless urs is as old as mine, there is a little label on the side of the trailer between the wheels.
once u find out, the important thing with aluminum rims is to retorque them after the 1st 50 miles (as close to the 50 miles as possible).
jimh is offline   Reply With Quote
Old 08-22-2011, 04:49 AM   #3
cardinal4fun's Avatar
I torque mine at 90 thats what was on the sticker. I also check the torque every so often to make sure the nuts are not coming loose. Those alum. rims do not hold the torque.
3500 Ram 5.9l diesel
08 35 RLT Cardinal
5th Airborne Pin Box
cardinal4fun is offline   Reply With Quote
Old 08-22-2011, 07:45 AM   #4
jimh's Avatar
i'm afraid i've always torqued mine by feel. sense that will change with the strength and weight, it isn't very scientific.
i don't think the tag warns u abt al rims. first time i encountered it was when i had a tire replaced on my truck. receipt came back saying to retorque at 50 miles. later i read that it was necessary to retorque al rims. that wasn't the first tire i've replaced but the first time i seen that on a receipt. the tire was changed in Ia.
Old 08-22-2011, 11:02 AM   #5
The Old Man
Willis's Avatar
I've had 4 TTs and the first three had steel wheels. I was always told to torque @ 90-95 ft/lbs and that seemed to work well. I have an old style "needle" type torque wrench but I think that gets it close enough.
My current TT has aluminum wheels which are beautiful. During the initial walk-through I asked the technician (who was very knowledgeable and competent) what torque I should use...he suggested 100-110 ft/lbs. I tried that with my existing torque wrench and at about 100 it really felt like I was starting to over-tighten so I left it at that.
I think what I want to do now is get a ratcheting torque wrench that you can set to your desired limit (say 100) and when it get to that point it "breaks" so you can't over-tighten. Expensive though!
Example: Amazon.com: Professional Grade 1/2" 30-150 Foot-Pound Automatic Adjustable Torque Wrench: Automotive
2010 Flagstaff 829RGSS
Still to go: AK, NL, NT, NU, YT
Willis is offline   Reply With Quote
Old 08-22-2011, 05:18 PM   #6
Thanks to all who responded to my question regarding proper torque on lug nuts. I'm shopping for a good Torque wrench.
Al fowlkes
Old 08-22-2011, 07:50 PM   #7
The torque required is directly related to the size of the axle studs.
As for the torque wrench to use, definitely buy a good one. Aluminum wheels need to be torqued correctly, and often. For some reason, aluminum wheels can work the nuts loose once in a while.
Old 08-23-2011, 10:17 AM   #8
You might call the company who makes your wheel. I did for ours. They should have all of the recommendations for a safe journey. As some have stated, you'll need more info than just your wheel brand and model, so be prepared.
Mike
traveler2955 is offline   Reply With Quote
Old 08-23-2011, 11:09 AM   #9
MtnGuy's Avatar
I remember using those. If you could see the gauge, they worked great.
Old 08-23-2011, 02:44 PM   #10
buckisland1950's Avatar
Check out the Husky Torque Wrench at HD. Good quality and direct replacement if it breaks...
2011 F250 Lariat Crew Cab 6.7L Diesel
2011 Flagstaff Classic Superlite 831 FKBSS
Fleet of Canoes and one Kayak
So Many Rivers so Little Time!
buckisland1950 is offline   Reply With Quote
