Old 11-02-2015, 08:30 AM   #1
Canadian Contingent
Dogpatch's Avatar
Need Skid Wheels?
I have a 3450RL.
It's 40'9" long with a fair overhang after the rear axle.
Recently, I got on a ferry and scraped my hitch and lost the lower section of my ladder.
I'm thinking of putting a skid wheel on the hitch or swivel skid wheels on the tubular cross bar further back.
I could weld a skid bar onto the hitch but would prefer something that rolls rather than scrapes.
Anyone else done this? Thoughts?
Les and Bonnie with 4 Leggers Bella and Shelby
2010 Cardinal 3450RL 4 slide Full Body Paint pushing our 2015 Ram 3500 Laramie 4x4 CCSB SRW - Pullrite 2900 Superglide 18k
Dogpatch is offline   Reply With Quote
Old 11-02-2015, 09:08 AM   #2
Lots of people have added Wheels,just remember what you Add will Drag/Roll Quicker! So keep the Diameter Small! Youroo!!
Old 11-04-2015, 07:18 AM   #3
Canadian Contingent
Dogpatch's Avatar
My thoughts would be just the singular wheel under the hitch. It's a stubby wheel about 2.5" wide that attaches via a hitch pin. It's the only point that touches now that the lower section of ladder somehow miraculously disappeared.
I would think if I put the two rollers on the tubular cross member, that coming out of a driveway at an angle, that only one wheel would touch and rack(twist) the frame.
Old 11-04-2015, 08:00 AM   #4
Sc00ter's Avatar
Wow that is long! We had a similar issue dragging the back bumper but it was due to our truck bed sitting so high and tipping the trailer aft. Our partial solution was to lower the vertical adjustment of our hitch and raise the king pin assy up a couple of inches. We gained about three inches on the bumper clearance. Looking into that lippert correct track alignment kit. Our axle alignment is good, but from what I have read it lifts the trailer by two inches.
2015 puma 295bhss
2009 ram 3500 6.7l ctd
Sc00ter is offline   Reply With Quote
Old 11-05-2015, 08:13 PM   #5
rugersdad's Avatar
That was my first mod I welded a pair of two inch rollers on the cross bar, no more hitch drag.
rugersdad is offline   Reply With Quote
Old 11-09-2015, 11:20 AM   #6
Not necessarily a good idea. While it lifts the trailer it puts way more stress on the spring hangers as they are now longer and will have more leverage which could result in twisting the frame or shearing off the hanger. There have been a couple examples showing this on the internet recently. Not so much a problem with the factory installed kit as they don't extend the hangers. In my opinion Correct Track is pretty worthless for alignment as it only addresses tracking but does nothing for toe or camber adjustments, but that's another topic.
GOTTOYS is offline   Reply With Quote
Old 11-09-2015, 05:03 PM   #7
Sc00ter's Avatar
I agree that it will increase some leverage on the spring hangers (basic physics) and that it won't solve toe or camber (that is dependent on the shape and bend of the axle). I do think it would work well in situations where the axles aren't square towards the frame and the tires don't track parallel. The irony is that it is a product marketed to fix out of square situations by the same company who built the trailers and potentially created the issue.
I am not being sarcastic (just researching- bought the kit and am planning on install this spring)... Do you have links specifically to correct track failures? I have searched and cannot find any. I know there are failures from shade tree engineering lift kits where excessive blocks are used, but only two inches IMHO shouldn't create enough force to make a difference. I worry more about the tires that came with the trailer.
2015 puma 295bhss
Old 11-09-2015, 07:44 PM   #8
There was an extensive thread on the Heartland Owners Forum a few months back showing how the frame rails twisted after installing a Correct Track. They suggested using the Mor-Ryde cross braces between the spring hangers or making your own out of some 2" square tubing to help stiffen the spring hangers. Made sense to me. Completely agree with your post regarding tires and how Lippert sells the kit to straighten THEIR frame. My axles were both swayed to the left 3/4" when I brought it to an alignment shop just after I bought it. I don't have a Correct Track. My alignment guy doesn't use them when they come in with one installed anyway. he just aligns it the old fashioned way, like he always did.
Old 11-09-2015, 07:55 PM   #9
Timex's Avatar
Originally Posted by Dogpatch View Post
I have a 3450RL.
My first thought, why didn't they put a third axle on one this long?
2012 Flagstaff V Lite 30 WRLTS
2005 Dodge Ram 2500 5.7 Mag Hemi 3.72 Rearaxle
Nights camped 2015 = 23
Nights camped 2016 = 25
Nights camped 2017 = 13
Nights camped 2018 = 3
Timex is offline   Reply With Quote
Old 11-09-2015, 08:12 PM   #10
Bluepill's Avatar
Skid wheel available at Etrailer.com
2008 Itasca Meridian 37H
wheel
