Old 10-22-2013, 01:00 PM   #1
no propane
I cant seem to get anything to work on propane, stove furnace or refridg? what am i missing??? Help!
r barker is offline   Reply With Quote
Old 10-22-2013, 01:05 PM   #2
Rugged Brown's Avatar
Propane maybe?
Terry/Bernadette
Lily the Yorkie
2015 Dodge Ram Sport 1500
2015 Crossroads Zinger ZT28BH
Rugged Brown is offline   Reply With Quote
Old 10-22-2013, 01:05 PM   #3
Possible causes: 1. Tank empty 2. Tank not turned on 3. Tank turned on too fast and safety valve activated. 4. Still have air in the lines that need to be bled out. 5. Bad regulator 6. Kink in the flexible hose.
Old 10-22-2013, 01:06 PM   #4
If you just filled the tanks, you may neede to bleed the air through the lines before th epropane ignites.
Terry/Bernadette
Lily the Yorkie
Old 10-22-2013, 01:39 PM   #5
Phat Phrog Stunt Crew
awwall's Avatar
7. Solenoid shutoff valve closed
Wayne & Susan Biloxi,Ms
2012 GeorgeTown 351DS...2015 Ford Focus/Brake Buddy
FROG Member
awwall is offline   Reply With Quote
Old 10-22-2013, 01:45 PM   #6
Brother Les's Avatar
hello r barker, welcome to the forum.
Have you ever had anything on your unit work in the propane mode ? How long have you had this unit and not used it? Turn one of the propane tanks on. Make sure that the lever is pointing to that tank. you will have air in the lines if not used for a week or so. turn on a stove burner and let a minute or two pass, while you have a lighter in hand to light the burner that is 'on'. Try to light it every 5 seconds after a minutes time of waiting. Do you 'hear' 'air' coming through the the stove burner? If not, then something is not right at the propane tank.
Brother Les
Old 10-27-2013, 05:43 PM   #7
I have changed both of the flexible hoses because of no flow. They have a check valve in them that goes bad. There is also an excess flow device in each propane tank. If the system is empty when you turn the tanks on the excess flow valve will activate. After the pressure has filled the lines you can turn the tanks off for a second then turn them back on. This will usually reset the excess flow valves. If this doesn't work it is probably the flex hoses.
wvcampers is offline   Reply With Quote
propane
