04-11-2016, 11:54 AM
Outside black water tank flusher
Problem!!! When I connect hose to outside black water tank flusher, I hear no water running and get no water discharge out of sewer drain. Can this be replaced?? Is it clogged?? If replacing, is it a very hard thing to do?? Tks in advance for any info!!!
04-11-2016, 01:50 PM
Find your vacuum break valve and see if installed backwards....lot of threads on subject...usually valve is under bathroom vanity...
http://www.forestriverforums.com/for...sh-101300.html
Fonzie
04-11-2016, 02:02 PM
fonzie has given you good advice.
Has it ever worked?
Many vacuum/break valves are plumbed backwards from the factory.
Many leak from the factory.
Most folks will replace the inexpensive plastic ones with higher quality brass valves.
04-11-2016, 04:27 PM
[QUOTE=5picker;1160824]fonzie has given you good advice.
Has it ever worked?
04-11-2016, 04:28 PM
Yes last year it worked fine
04-12-2016, 12:46 PM
fonzie How do you tell if it is installed back words,
04-12-2016, 12:57 PM
See diagram....
Fonzie
04-12-2016, 12:59 PM
Left Coast
Water comes in on the bottom end and exits out on the 90 degree end
04-12-2016, 01:56 PM
Thanks fonzie
04-12-2016, 01:57 PM
When using the black tank flush should we still use the regulator?
Thanks again
04-12-2016, 02:03 PM
Thanks again
I have never used the pressure regulator when flushing. And it goes without saying to NOT use your regular water hose to flush with.
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2021: 35 nights already booked so far
04-12-2016, 02:10 PM
Correct. Having to unscrew hoses from regulator was part of the question.
04-12-2016, 04:47 PM
Left Coast
I would due to plastic back flow valve
Sent from my XT1080 using Tapatalk
04-12-2016, 06:28 PM
I think the black ones are rated to 125psi and the clear ones are rated to at least 200psi. But of course, one never knows for sure. Probably best to be safe than sorry.
04-12-2016, 06:38 PM
Left Coast
When it starts leak'n, and it will, go to HD or Lowes and get a brass one for a house and get rid of factory one and 12' of extra hose
04-12-2016, 06:41 PM
Canadian Member
I had an external plastic backflow preventer that blew apart from too much water pressure. I replaced it with a brass unit but when we go back to that Provincial Park I may use a dedicated pressure regulator, too.
04-12-2016, 06:47 PM
Canadian Member
I bought our TT used and discovered that the previous owner must have had the black plastic backflow preventer break because he had replaced it with a bend.
(Sorry the picture is sideways.)
