Old 04-11-2016, 11:54 AM   #1
Outside black water tank flusher
Problem!!! When I connect hose to outside black water tank flusher, I hear no water running and get no water discharge out of sewer drain. Can this be replaced?? Is it clogged?? If replacing, is it a very hard thing to do?? Tks in advance for any info!!!
Cardinal camper is offline   Reply With Quote
Old 04-11-2016, 01:50 PM   #2
fonzie's Avatar
Find your vacuum break valve and see if installed backwards....lot of threads on subject...usually valve is under bathroom vanity...
Black Tank Flush
Fonzie
Old 04-11-2016, 02:02 PM   #3
Pickin' & Campin'
fonzie has given you good advice.
Has it ever worked?
Many vacuum/break valves are plumbed backwards from the factory.
Many leak from the factory.
Most folks will replace the inexpensive plastic ones with higher quality brass valves.
Days Camped: '15=22 '16=46 '17=30 '18=4
Old 04-11-2016, 04:27 PM   #4
[QUOTE=5picker;1160824]fonzie has given you good advice.
Has it ever worked?
Old 04-11-2016, 04:28 PM   #5
Yes last year it worked fine
Old 04-12-2016, 12:46 PM   #6
mike.t's Avatar
fonzie How do you tell if it is installed back words,
2015 Salem 27RKSS
2015 Ram 2500 CC 4x4 Cummins
55' Chevy Bel-Air
Burgers on the BBQ and a cold beer
mike.t is offline   Reply With Quote
Old 04-12-2016, 12:57 PM   #7
fonzie's Avatar
See diagram....
Fonzie
Old 04-12-2016, 12:59 PM   #8
Left Coast
Water comes in on the bottom end and exits out on the 90 degree end
Old 04-12-2016, 01:56 PM   #9
mike.t's Avatar
Thanks fonzie
2015 Salem 27RKSS
55' Chevy Bel-Air
Old 04-12-2016, 01:57 PM   #10
mike.t's Avatar
When using the black tank flush should we still use the regulator?
Thanks again
2015 Salem 27RKSS
55' Chevy Bel-Air
black, black water, tank, water, water tank
