Old 10-24-2015, 08:44 PM   #1
Paint Cracking Issue
Hi guys! New here on the forum. I tried to respond to an old thread regarding the paint Cracking on the caulking but it wouldn't let me.
Anyway I have a 2013 Cardinal 3675 with the same issue and wondering how the others that previously posted about this issue had it repaired? I bought this fiver used so I have no warranty. Hoping its an easy fix.
Thanks in advance!
918jeeper is offline   Reply With Quote
Old 10-24-2015, 11:17 PM   #2
jacknife's Avatar
Get the paint # and mix it with your caulking.
jacknife is offline   Reply With Quote
Old 10-24-2015, 11:28 PM   #3
How do you mix paint with caulking? Is there a particular type of caulking you use with the paint?
Old 10-25-2015, 09:46 AM   #4
Okay did some research on adding paint to caulk. Now can anybody tell me where to find the paint code?
Old 10-27-2015, 02:36 PM   #5
jacknife's Avatar
What color is it ? I have 3 different colors with # on then black kinda gray brown and creme.
Old 10-27-2015, 06:52 PM   #6
That's the same color scheme on mine.
Old 10-27-2015, 11:17 PM   #7
jacknife's Avatar
Call Cardinal and they should have the color codes . Get dicor roof caulking. Just fill in what is cracked.
Old 10-27-2015, 11:19 PM   #8
jacknife's Avatar
My touch up paint had no color xodes on it. Sorry.
Old 11-09-2015, 07:38 PM   #9
Just an update on how I took care of my painted over caulking Cracking issue.
First I used a razor knife to carefully cut and scrape the flaking paint off the original caulking.
As advised by Jackknife I mixed matching paint with the caulking and caulked over the areas I scraped. Some areas were large globs of caulking that had peeled away from the surface leaving the unpainted white surface exposed.
The lighter colored areas worked best with the paint colored caulk but the black did not look as good. So I used a small artist brush and painted or dabbed the exposed areas with the touch up paint. After letting it dry thoroughly I then caulked over those areas with clear ProflexRv caulking. I found this method to work the best rather than using paint colored caulk. Very time consuming and still working on it. Hope this helps anybody dealing with this issue on their own.
