Old 09-20-2015, 03:58 PM   #1
Power awning question
We have a 2015 Cardinal (3675) which has two power awnings. One works fine, the other one (17 foot one) worked fine until last trip. It wouldn't extend. I can hear the motor click from outside, but no movement. I checked out the switch and it has only 3 wires attached, so I'm assuming there has to be a control box someplace. My question is does any Cardinal owner have any idea where it might be located.
sam2424 is offline   Reply With Quote
Old 09-20-2015, 06:22 PM   #2
TURBS's Avatar
No control box to my knowledge.
If motor clicks it's possible something is wrong.
It's under warranty correct?
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "27 nights"
Old 09-20-2015, 06:31 PM   #3
Ours did that two weeks ago. I used a socket wrench on a cordless drill to manually extend the awning an inch then it worked fine the rest of the week.
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2021: 35 nights already booked so far
Teamfour is offline   Reply With Quote
Old 09-20-2015, 06:31 PM   #4
bubbles's Avatar
Correct, no control box. The motor is a simple 12 volt dc motor and the awning switch just reverses the polarity (both 12 volt and ground) for extend and retract. OP said only 3 wires to switch.There should be 4 wires connected to the switch.
Old 09-20-2015, 06:38 PM   #5
TURBS's Avatar
Ground
Power
In
Out
TURBS
2011 32bhok Sabre
Old 09-20-2015, 07:32 PM   #6
Power awnings
I agree power to operate awning is 12 volts. My care free switch had 6 wire attached (12 v, ground, and through switch its self, it reversed polarity). But only using 3 wires to switch, it is impossible to reverse polarity (power and ground) with out a control box. Besides that piece of information, the internet tells about a control box. My question is where is the control box in a 3675 Cardinal (2015). And to answer one response, yes it is still under warentry, but I have come to find if you have something fixed under warrenty they always break something else in the process and besides that if I don't learn anything now, what am I to do in the middle of campground with no knowledge of how to get back on the road.
awning, power
