Old 05-07-2018, 03:52 PM   #1
Power control system
Would someone explain what this panel does. Am i supposed to change something such as when I run a external generator or 30 amp.
Or is this just a panel telling me whats going on.
Kwralph is offline   Reply With Quote
Old 05-07-2018, 06:32 PM   #2
That panel is part of what is called a power management system. It's function is to perform load shedding when your 50 amp rig is plugged into something less than 50 amps(30 or less). It does a good job automatically detecting 50 vs 30 amp circuit. When the overall power draw exceeds 30 amps, it will automatically cut the power to the few high amperage devices shown(a/c, wh, etc.) Somewhat seamlessly, so that you don't notice too much.
The only thing you can do is to manually downgrade your service so that it more agressively cuts out certain devices if the post you're plugged into isn't up to the task.
I don't do much with it, except occasionally see what mY amp draw is when not on 50a service.
Dave
2017 Cardinal 3850RL Mocha Pearl full body paint
2016 F350 Lariat 4x4 FX4 SRW CC SB 6.7 Magnetic Metallic
djousma is offline   Reply With Quote
Old 05-07-2018, 09:26 PM   #3
Well said.
Michael & Fran Dilday (Baxter & Honey 2 Labs)
'18 Cedar Creek Champagne 38EL - '17 Ford F350 Lariat DRW w/Reese hitch - TST 507 Color TPMS - Garmin RV 770 LMT GPS
mwdilday is offline   Reply With Quote
power
