Old 10-19-2015, 09:03 AM   #1
Canadian Contingent
Dogpatch's Avatar
Rear Stabilizer Jacks?
Are the rear stabilizer jacks just supposed to come down and stop or should they continue to raise the back end?
Mine stop on contact with the ground. Sounds weak.
Les and Bonnie with 4 Leggers Bella and Shelby
2010 Cardinal 3450RL 4 slide Full Body Paint pushing our 2015 Ram 3500 Laramie 4x4 CCSB SRW - Pullrite 2900 Superglide 18k
Dogpatch is online now   Reply With Quote
Old 10-19-2015, 09:23 AM   #2
Witch Doctor's Avatar
You see the rear end pick up a little if you watch then release the button. If you hold it to long it will pop your reset. They should have pressure on them and the only way they wouldn't if you let off the button before it moves up. Keep an eye on them when they both hit the ground. If your on a slight slope one will touch down first then the other, then both are on the ground solid you will see the rear pick-up a little then your done and solid.
Coachmen M/H
Concord
2018 / 300 DSC
Old 10-19-2015, 09:30 AM   #3
Are these just the Lippert Elec/Gearbox type or Elect/Hydro? On a full body paint Cardinal I would think Hydro! Youroo!!
Old 10-19-2015, 01:02 PM   #4
I think he only has the lippert elec. gear box, last week he tripped the auto reset on the motor if I'm not mistaking.
Coachmen M/H
Concord
2018 / 300 DSC
Old 10-19-2015, 06:48 PM   #5
Canadian Contingent
Dogpatch's Avatar
I believe they are the Lippert brand on the Cardinal.
Old 10-19-2015, 08:16 PM   #6
I'm almost positive that they are. The sound of the motor will slow and you will hear it. Just keep it pushed until you see a slight lift. Trust me those motors will handle the pressure. The worst can happen is that it will trip the auto reset. You will get the hang of it...
Coachmen M/H
Concord
2018 / 300 DSC
Old 10-19-2015, 08:39 PM   #7
Canadian Contingent
Dogpatch's Avatar
Thanks! Being my 1st fifth wheel, I just wasn't sure what to expect from them.
jacks
