07-08-2015, 08:52 PM
Refrigerator/Freezer not keeping cold enough
We have a 2010 Cardinal 3450RL. Overall we love the Cardinal. Sometimes the fridge foes not stay cold enough and the freezer does not keep ice cream frozen ( yea I known, a lot of sympathy for a camper with ice cream problems ). I have it set on 5. The only thing I could find is the when I removed the outside covers I only saw one cooling fan running. Are they both supposed to be running?
07-10-2015, 03:01 PM
Fans will run when the temp gets up there. Check the spacing between the wall and the refridg. It should only be one inch. You may have to install baffles to direct the air to the coils. Also check the burner box in the outside compartment. If you see green dust, your refer is going out.
07-10-2015, 03:12 PM
Put in bigger fans!
I put three fans on the outside and one in the inside
180 mm computer fans.
What a difference!
Also if one is running they both should be running.
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "11 nights"
07-10-2015, 03:23 PM
My outside fans run when ever the disconnect is on. Cured my all my cooling problems
Jason and Billie
2018 F-250, 6.2L
2011 Prime Time Crusader 320RLT
07-10-2015, 04:50 PM
Installing 1 pulling in and 2 pushing out of vent this weekend. Got package deal on Amazon for 5 120mm fans for 20 bucks!
Anyone need a fan?😜
Just glad to get away
07-10-2015, 08:16 PM
Thanks all. Mine only has 2 fans and only one was running
I attached a picture of one of my fans. Do you know what size that is? I think 3 would be a great idea.
07-10-2015, 08:44 PM
be sure to be level. gas side may need service. be sure resettable thermodisc with the 2 red wires is present on burner chamber.
07-10-2015, 08:50 PM
I believe those are 92mm fans. If you google the model number and make of fan the web site will tell you.
I have 2 of those fans on back side I also added 5 more fans near the fins and have then on a thermostat connected to the fins. Now fridge stays at 32 degrees no matter how hot it is outside.
Also I have 3 sets of fans mounted inside my fridge to move air around.
2014 cedar creek 36ckts
2014 Chevy 3500 1 ton crew cab 4x4 long bed.
07-11-2015, 01:14 AM
those fans ought to reduce core temperatures and increase life too. how about an 180 degree ECO to cut them off in the event of a fire? your furnace and your water heater has one.
07-11-2015, 02:46 PM
I'm going to go a different direction here. I used to own a resort with lakeside housekeeping cabins where folks came and stayed for a week. Most folks checked in midday and loaded the full size kitchen refrigerators full -- both freezer and refrig sides. I could almost guarantee in the evening or the first thing the next morning at least one would be in the office complaining that their refrig wasn't keeping things cold enough. Nothing was wrong with the frig -- it just took the poor thing hours to catch up with all of the semi to warm stuff they had jammed in it. Worst culprits were usually a case or two of beer and soft drinks. All of the other suggestions are certainly valid, but be considerate of your refrig and whenever possible -- start it a day before and load it with cold or frozen things to start the trip.
07-11-2015, 04:51 PM
Thanks. All. Really great help. I will update after our next trip.
07-11-2015, 05:50 PM
Mine stopped working well, ended up being the sensor fell off the adjuster.
2015 Tracer ultra light executive edition 3200bht
2007 Dodge Ram 3500 Cummins 6.7, Dually, crew cab, long bed
07-12-2015, 06:55 AM
Do all fridges have fans installed in outside compartments? I do not see any in mine...J
07-12-2015, 07:00 AM
Jim, ones in slides have them for sure. Others not so sure.
Also if you are having cooling problems switch over to Propane. I my experience works much better than electric operation.
B and B
07-12-2015, 07:03 AM
Some do and some don't, but it's an easy, cheap mod. I put two in the outside compartment just above the burner and blowing up across the entire coil assembly. Also put 2 inside the frig for circulation. Our Norcold freezer maintains -5°- +0° and the frig maintains 31°-34° with the control on 3 in all weather from 35° to 100°, in shade or direct sun.
07-12-2015, 07:36 AM
My Silverback 20RE fridge is in a slide ....I do not see or hear any fans outside unless they are in middle section between the two side vents???????.J
07-14-2015, 08:00 AM
I went ahead and ordered 2- 120mm fans yesterday. I tried testing it last night by "temporarily" installing a 12 cooling fan from a motorcycle. The fan moves a lot of air and in about 4 hours the freezer was down to 15 degrees but the refrigerator was only down to 60. How cold should the freezer and the fridge get? How long should it take to get there? Thanks
07-14-2015, 09:16 PM
Jim. That is where my fans were. Remove the top vent and look down inside.
07-15-2015, 07:09 AM
Mine gets to 32 in fridge and about 10 in freezer if I had to guess what freezer was.
07-15-2015, 07:44 AM
Thank you. That will help in knowing when I get this fixed. From a warm startup how long does it take to get to working temperature? Thanks
