Old 03-07-2018, 02:30 PM   #1
racindirt06's Avatar
Refrigerator water line
Anyone know where the water line shut off for the refrigerator is located on a 2017 3825FL? The dealer doesnít even know! Thanks
racindirt06 is offline   Reply With Quote
Old 03-07-2018, 02:37 PM   #2
WalkingTall's Avatar
Yeah if you open the basement door where your water hook up is you have to un screw the wall behind it. You will see your hot water heater and the refrigerator shut off there. It not to hard to get to. I have so pics I'll try to find and post
2016 Forest River Cardinal 3825fl
WalkingTall is offline   Reply With Quote
Old 03-07-2018, 02:47 PM   #3
Thank you! The dealer kept telling me itís a cabinet close to the refrigerator
Old 03-07-2018, 02:59 PM   #4
If you'll look at my posts the post named residential fridge has pictures of the shut off. Here's the link also
Residential fridge
Old 03-07-2018, 03:05 PM   #5
cavie's Avatar
That's in the real world. RV world not so much.
2011 Keystone Sprinter 323BHS
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 03-07-2018, 03:08 PM   #6
I see it in your picture! I would have never found that. Thanks again.
Old 03-07-2018, 03:31 PM   #7
No problem. If it hadn't been for the people on here I wouldn't have found it either.
Old 03-07-2018, 08:25 PM   #8
kudos to walking tall! we have a 2015 3825fl cardinal. that little valve is impossible to find by yourself. thankfully I found it after reading about it on the forum. on ours it is on the floor behind the water heater. you have to unscrew an access panel in the basement wall to be able to get into that area. I had to trace the white plastic water line going to the refrigerator to actually find the valve.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
CHICKDOE is offline   Reply With Quote
Old 03-07-2018, 08:34 PM   #9
In my 2017 3850RL, they moved that valve into the water bay controls area. Very handy.
Dave
2017 Cardinal 3850RL Mocha Pearl full body paint
2016 F350 Lariat 4x4 FX4 SRW CC SB 6.7 Magnetic Metallic
djousma is offline   Reply With Quote
Old 03-08-2018, 12:22 PM   #10
It came that way or you had the dealer move it?
Old 03-11-2018, 05:42 AM   #11
It came that way from the factory.
Dave
Old 03-12-2018, 07:32 AM   #12
Iíve got 14í 3850rl and itís behind the wet bay, had to open the access panel. Really didnít know how the valve worked. Brother is a plumber and heíd never seen a valve like it.
Rbare31 is offline   Reply With Quote
Old 03-14-2018, 06:10 AM   #13
Poor location, but its just a push/pull type valve. what you cant see in your photo is the smaller line that goes to the refrigerator.
Dave
refrigerator, water
