Old 10-08-2019, 01:07 PM   #1
Safety Light
Hey. I have a 2019 Cardinal 3456RLX & I do not see a way to turn off the safety light on the stairs going up to the bedroom. It is located beside the vac system on the stairs. It bothers others when they are trying to sleep in the living room. We have to throw a towel over it. Is there any way to turn it off?
Thanks,
Jhelmey is offline   Reply With Quote
Old 10-09-2019, 08:18 AM   #2
SeaDog's Avatar
I don't know your specific rig but I would think just pull the light, cap off the wires reinstall the light and its a done deal.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 10-09-2019, 09:08 AM   #3
Thanks,
As Seadog mentioned you could just disconnect it. But, if you are electrically inclined, I'd probably either buy a different fixture, that has an on/off switch so that you have the option to use or not use and replace it or install a separate toggle switch to do the same. My last choice would be to just remove the bulb if accessible without cutting or disconnecting any wires.
Dave
2017 Cardinal 3850RL Mocha Pearl full body paint
2016 F350 Lariat 4x4 FX4 SRW CC SB 6.7 Magnetic Metallic
djousma is online now   Reply With Quote
Old 10-11-2019, 02:22 PM   #4
My safety light
The safety light on my 3950 is activated by a switch on the screen door; maybe yours too, in which case it my be a faulty switch.
Guru is offline   Reply With Quote
Old 10-12-2019, 06:54 AM   #5
I have that on my 3850, and those are for the entrance. I think the OP is talking about a different light for the steps to the bedroom.
Old 10-16-2019, 03:32 PM   #6
Cardinal Customer Service
Safety Light
Just a follow up to this thread....this light shuts off when the magnet on the entry door meets the magnet on the frame of the door. It turns out that the wire for this light was pinched. It was getting continuous power and would not shut off. I hope this helps answer any future questions.
Anita Carpenter is offline   Reply With Quote
Old 10-16-2019, 06:25 PM   #7
Thanks Anita!
light, safety
