Old 03-05-2019, 11:50 AM   #1
Satellite cable cover on roof
Trying to figure out what's what in the cables before my Dish equipment arrives. Took off the Sat cover on the roof and found a gray coax loop, uncut. I have 2 tvs in the coach (Cardinal 5th wheel 2017). Wondering if I have to cut the cable and each piece goes to a different tv. Advice?
bmrbob is offline   Reply With Quote
Old 03-05-2019, 01:15 PM   #2
That would be my guess. but how you wire will be dependent on which satellite service you are getting. If Directv with the traveler HD dish, that will be SWM, and there is only one connection to the dish. OLder style dishes would have a dedicated run from the satellite to each of the TV's, with one of them connecting as primary, and the other as secondary. Those are a real PITA, because those dishes cannot see all satellites at the same time, and from the primary TV depending on the channel you select, will cause the dish to move, and whatever was being watched on the secondary tv will be affected as well.
Dave
2017 Cardinal 3850RL Mocha Pearl full body paint
2016 F350 Lariat 4x4 FX4 SRW CC SB 6.7 Magnetic Metallic
djousma is offline   Reply With Quote
Old 03-05-2019, 01:24 PM   #3
Dish Network, 2 receivers, and a Tailgater dual cable dish.
Old 03-05-2019, 09:06 PM   #4
Itís a single cable wired to your living room TV area up to the roof and then back down to the bedroom TV. Youíll cut and terminate it on the roof and end up with a direct run to each location.
John Taylor
2019 Newmar Bay Star 3609
2018 Cardinal 3350RLX - sold
2013 Cardinal 3030RLS - sold
jtaylor1920 is offline   Reply With Quote
cable, cover, lite, roo, roof, satellite
