Old 10-26-2017, 09:58 PM   #1
Slide out switch makes front Jack's extend and retract
I have a 2016 Cardinal 3850 and having issues with level up system when I try auto level the middle and rear Jack's don't extend to the ground but it says auto level successful. I have replaced the front and rear controls and no change it is on my drive way which is pretty level. If I raise the right side up higher with a board than left side it will work correctly.also if I hold down the main slide out switch after slide is extended or retraced the front Jack's go up or down has anyone else had this happen.lippert did send me the parts no charge but not much help. Thanks
Tnvolmam is offline   Reply With Quote
Old 10-30-2017, 02:57 PM   #2
jacknife's Avatar
Did this just start ?
jacknife is offline   Reply With Quote
jacks, slide, slide out, switch
