Old 06-23-2016, 06:35 AM   #21
cpaulsen's Avatar
Will try to a pic today and get it posted.
cpaulsen is offline   Reply With Quote
Old 06-23-2016, 08:44 AM   #22
Restcure's Avatar
Originally Posted by bob caldwell View Post
Re-tensioning sounds like the best way.....
Agreed... I just need to figure out how to re-tension ours (Dometic AE)...
2012 Rockwood Ultra-Lite 2701SS, Goodyear Endurance LRD, ProPride 3P 1400 hitch
2013 F-150 FX4 7700# GVWR SuperCrew 3.5L EcoBoost 157" WB Max Tow 3.73:1
John, Dawn and Emily... and Bella the camping kitty
visit our website at www.restcure.ca
Restcure is offline   Reply With Quote
Old 06-23-2016, 09:31 AM   #23
Left Coast
Un sure if toppers have 1 or two springs, an awning has one....
Sent from my XT1585 using Tapatalk
Old 06-23-2016, 09:45 AM   #24
Slide toppers have torsion springs on both ends.
File Type: pdf Dometic Slide Topper Service Instructions.pdf (892.8 KB, 38 views)
Old 06-23-2016, 09:49 AM   #25
Left Coast
Can a person take an arm loose and wind it rather than removing rivets to tension?
Old 06-23-2016, 09:52 AM   #26
Yes, that's how you do it by adding more torsion with the arms.
Old 06-23-2016, 09:54 AM   #27
Left Coast
Got it....thanks
Old 06-25-2016, 10:21 AM   #28
shughey00's Avatar
I use the LARGE pool noodles. Cut em just a tad long and wedge em in about every four feet.
Guess Using a rope to tie em all together would make removing em easier but I have a broom stick I just use to knock em loose. Then again I seasonal so it is a once a year in and out.
I tried tightening the tension on the 12 foot slide but as I posted before the tension does not help because the length of the roller is so long it is not rigid enough on its length to resist bowing in at the center. So more tension does nothing about the center sag...helps the ends but not the center.
2004 Cedar Creek 34CTKS heavily customized
2006 Ford F350 FX4 Lariat Dually w/tow boss
1999 Lance 1110...cause it's easier for short trips.
shughey00 is offline   Reply With Quote
slide
