Old 04-12-2015, 02:10 PM   #1
Question Step Ladder, carry, why?
Hello,
we see a lot of folks with stepladders strapped to rear roof ladders, what are pros and/or cons of hauling the step ladder around?
Wanderer
2008 Cardinal 30RK fiver.
2009 Chevrolet 2500HD DuroMax
2009- 42 days; 2010-40 days, 2011- 40 days. 2012- 30 days,
2013- 14 days, 2014- 21 days, 2015- 42 days
2016-17 days, 2017-zero days
Wanderer is offline   Reply With Quote
Old 04-12-2015, 02:16 PM   #2
I believe the carrying of step ladders is so you can clean off the slide top before retracting if you don't have slide toppers . But I might be wrong,
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
wana65stang is offline   Reply With Quote
Old 04-12-2015, 02:20 PM   #3
Blackhat6mike's Avatar
I have the Carefree awning that does not droop down to clear the leaves and debris when I roll it up. Also, I need to clean solar panels now and then. The ladder will be used if, God Forbid, a leak occurs.
Aviator Wright Flyer #1919
Army Pathfinder Vietnam, 3 tours
DAV, MOPH, VFW, NRA, 1stCav. ABN
Blackhat6mike is offline   Reply With Quote
Old 04-12-2015, 02:21 PM   #4
Ford Idaho's Avatar
One uses is to gain access to the top of the slides to sweep off debris from trees that may cause problems when pulling in the slides.
Window washing, light bulb changing or hanging lights.
Con: if not secured correctly it could fall off, that would be very bad.
Old 04-12-2015, 02:35 PM   #5
Herk7769's Avatar
If you need one; there is no substitute.
Had to do emergency awning maintenance that would have been impossible without one.
HAM CALLSIGN - KC3FFW
Old 04-12-2015, 03:40 PM   #6
Amen, Herk! On our way to Colorado last June, we ran into massive winds while going thru Kansas. The slide topper started to flutter and wound up ripping about 6". Pulled in to a rest area to repair it. Had no ladder. Nobody else had a ladder, so they said, to loan. I talked a tanker truck driver to pull next to my rig so that I could use the ladder attached to his tanker. I managed to bungee both ends of the slide topper with the help of his tank ladder. I've been carrying a step ladder since. Wife didn't get any pics. Later that night at the campground, the news said the winds had blown a semi truck & trailer over in the area we were making the repairs.
Bob
2013 Ford F250 SD 6.7L
2014 Wildwood Heritage Glen 282RK
Certified Rumble Strip Tester
retiredcamper47 is offline   Reply With Quote
Old 04-12-2015, 04:11 PM   #7
Love My Sunseeker
DXSMac's Avatar
Mine is in a storage bay, but I use it for changing lightbulbs, or replacing screws that come loose.
JJ only, my cat went to Rainbow Bridge July 2015
I love my Sunseeker, when I'm on a trip I don't wanna go home!!!"
Total days camping each year: AS MUCH AS POSSIBLE!
DXSMac is offline   Reply With Quote
Old 04-12-2015, 04:31 PM   #8
BOBFIDY's Avatar
We carry a 4' ladder n the pickup...just to sweep off the top of the slides before moving them in. Not enough to get on top.....but it does serve its purpose.
2011 FORD F350 CREW CAB DUALLY DIESEL 4x2
2010 Salem LA 292FKDS
One of the Original 14 F.R.O.G.s
1st, 2nd, and 3rd INTERNATIONAL F.R.O.G. RALLY Branson. MO.
1st, 2nd, and 4th INTERNATIONAL RALLY Goshen, IN.
BOBFIDY is offline   Reply With Quote
Old 04-13-2015, 08:30 AM   #9
I "usually" carry a 6 ft'er. BUT, I have mine over a bicycle ladder rack. Then 6 HD zip ties, 2 to hold the ladder sections and 4 to secure it. I believe the rear cap would fall off before the ladder😃.
Anyone with those "collapsable" ladders, please share experience.
Considering buying one. With grand kids and 5 total bicycles, need that ladder rack on some vacations. Hate being without a ladder of at least 6 feet.
SilverbackMel is offline   Reply With Quote
Old 04-13-2015, 08:35 AM   #10
Flybob's Avatar
I carry an 8ft. one in the bed of the TV. I use it and an auto windshield squeege head on a short painters pole to clean off the slide out. It is also insurance when something falls on the roof during a storm. I can check it out and make repairs as needed.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
