Old 04-16-2015, 12:43 AM   #1
Surge protector install
Can anyone tellll a surge protector on a forest river cardinal. There is no access near the shore power receptacle.
safrog is offline   Reply With Quote
Old 04-16-2015, 05:33 AM   #2
davel1971's Avatar
where is the receptacle located? Most can be accessed from the basement area. That's how I got to mine
David & Lynn
Old 04-16-2015, 06:31 AM   #3
TURBS's Avatar
Behind your electrical panel?
TURBS
08 duramax tuned n modded, 32bhok Sabre
2015 camping "2 nights"
Old 04-18-2015, 12:06 PM   #4
Receptical is on rear. Have a rear living room with sofa in rear. There is a small shelf on each side. The. Receptical is behind the panel. Unfortunately, there is no way to get behind the panel without destroying it. Looks like I will have to place it behind the extricated panel.
Old 04-18-2015, 06:20 PM   #5
Dave_Monica's Avatar
You don't have to do anything where the power comes into the camper. Where is the breaker panel? Is the back of it accessible from the basement storage?
Dave
Old 04-18-2015, 06:25 PM   #6
Learjet's Avatar
Turn off all power and uplug, turn off 12 volt and disconnect battery...then
Take the cover off your power center, should be 2 or 4 screws
Once the cover is off, you'll see more screws holding the power center in the cabinet, take those off and pull our power center.
-2017 Ram Cummins, Aisin DRW 3.73, 4x4
-2015 Wildcat 317RL
-B&W Companion , MorRyde pinbox
Learjet is offline   Reply With Quote
Old 04-21-2015, 08:22 PM   #7
