Old 08-28-2016, 05:27 PM   #41
Happy Keystone Owner
dbarr's Avatar
Originally Posted by Airdale View Post
1K is Doublestar but they don't seem to have ST tires.
China Tyre, Tire, PCR Tyre supplier - Doublestar-Dongfeng Tyre Co., Ltd.
ST205/75R14
It's a 5212, maybe they're not making them anymore at that factory.
Season for long distance travel is over and these last 2 will be junked in the spring.
'15 F150 Ecoboost Maxtow Scab '19 Keystone Laredo 225MK
Days camped 2020-37 2019-36, 2018-24, 2017-46, 2016 -56, 2015-33,
2014-47,
Years camping....55
dbarr is offline   Reply With Quote
Old 08-28-2016, 05:52 PM   #42
Originally Posted by Tireman9 View Post
You should have the full DOT S/N for each tire recorded with the info kept with other important documents. With this info in hand you can easily check against any recall list as tire recalls are always based on the DOT serial number.
I suggest you pick a nice day to record each number. They may or may not all have same number as tires are made in batches of a hundred to 1,000. You may find some tires have the full serial (including the date code portion) on the inside so you might need a flash light or even have to move the RV to get the number fully visible.
Note there is no O or Q but do have the number zero. Also no i but do have the number 1
I assume this is the s/n you are referring to. Three were easy but the fourth was a b...h since it was on the inside and I had to snakecrawl underneath to get the pix.
I have the pix of all four numbers saved in a database I use for all the TT records.
BIRDS AREN’T REAL
Old 08-28-2016, 11:00 PM   #43
Commercial Member
the "full S/N" for your tire is all the letters and numbers right after the "DOT" and would end with the date code portion of 2715.
the 539303 is not part of the DOT S/N but is a tire company number.
The SN could be 8 to 13 characters long.
1st 2 are a code for actual producing plant and last 4 are date code. other characters are controlled by the tire company.
.Write a blog on RV tire application RV Tire Safety. 48 years experience as tire design & forensic engineer. My RV Freelander 23QB on Chevy 4500 chassis. Giving seminars on RV Tire applications (not selling)@ FMCA Conventions. Mar 20-22 Tucson AZ
Tireman9 is offline   Reply With Quote
Old 08-28-2016, 11:07 PM   #44
Commercial Member
Originally Posted by dbarr View Post
So what's the 3rd digit? A Chinese M?
BTW...that's a 19837 mile Trail Express! Well documented.
Interesting. Never seen a Q as I recall. But the characters that r most important are the 1st 2 (plant code)
1K in your case
and last 4 numbers which r the date code.
recall, tire
