Old 06-08-2016, 09:08 PM   #31
Commercial Member
Originally Posted by emm-dee View Post
Yes, in theory ISO looks pretty good. I worked with a company that was getting ISO certification and half way through the process they changed their mind. Everyone agreed it followed the concept of "it's not what you do, it's what you put in writing". The feeling was the process of documentation was so cumbersome it would take away efforts to continue producing a quality product.
But, ISO created a giant cash cow for the folks who started the concept. Probably European.
You are correct that in 2001 the focus was on documentation in QS9000. As I understand it the idea was that if you didn't have a written "Standard Practice" policy of what and how the job was to be done how could you expect to do a consistent job.
By 2005 with ISO8991, this had changed so there was much less focus on documentation and more on consistent results.
I do have to say that the documentation at Coachmen in 2007 & 2015 on electric wiring in the Freelander Class-C was not much better than something written on back of napkin. No wire color coding, only a few lines identified by gauge. The reality in both of my coaches was no where near what was shown on the drawing. Some wires were simply not shown on the drawing and others were shown on drawing but not in the coach. Plumbing drawing is worse. Some parts like water pump are installed before bathroom floor layed down leaving about 2" for your hand and screwdriver to get to hidden screws holding pump to sub floor. How about electrical tape used around pex water line at a fitting?
My list goes on and on. There were even instances where FR could have saved some $ by having low point drains a bit shorter and not end up draining on electric connections under the coach.
Good quality is a culture and has to be based on real commitment from top down.
Write a blog on RV tire application 40 years experience as tire design engineer. Freelander 23QB on Chevy chassis is my RV. Giving seminars on RV Tire applications (not selling) in Elkhart May 17-19, Allegan MI June 6-9, & Gillette WY July 18-21 RV Tire Safety Blog
Tireman9 is offline   Reply With Quote
Old 06-10-2016, 01:50 PM   #32
jacknife's Avatar
Maxxis heavy duty are a good tire
jacknife is offline   Reply With Quote
Old 06-10-2016, 01:56 PM   #33
Originally Posted by Tireman9 View Post
In theory ISO cert is checked by "super auditors" from LLoyds. Not saying it can't be "bought" but having worked on both sides (internal and external auditor) it was real for the tire companies here in the US and would be surprised if non-us suppliers didn't have to prove themselvs to "Detroit" also...
I was an ISO auditor for Lockheed Martin for 10 yrs and the ISO standards only require the mfg to follow procedures, they do not dictate ingredients or products.
tire, tires
