06-06-2016, 11:55 AM
Tires (again)
One of my Goodyear Marathons blew the other day so I'm getting new tires. I have a 2016 Cardinal 3875FB. I have a chance, if I wait a week, to get Sailun tires with 14 ply and a G rating. If I go with what's in stock I can get E rated 10 ply TowMax or the 10 ply E rated version of Sailuns. Advice?
Also Goodyear hasn't committed to cover the repair to my rear quarter panel and fender skirt yet. Has anyone gotten than to do so for you? Any advice on how to get them to stand up for the repair? TIA
The Normans
2014 Chevrolet 3500HD
06-06-2016, 12:11 PM
Really sorry to hear that happened to you. Just reinforces in my own mind that I made a good decision adding the G-rated tire upgrade when I placed my order. Just curious, did you have them aired up to proper inflation?
Our 3850RL is getting delivered in just 2 short days(that will seem like forever).
Dave
2017 Cardinal 3850RL Mocha Pearl full body paint
2016 F350 Lariat 4x4 FX4 SRW CC SB 6.7 Magnetic Metallic
06-06-2016, 12:33 PM
Inflated properly and not overloaded, driving on out 60 mph. I found I cannot get the Sailun or Michelin G rated tires so if I want G rated I have to get Goodyear G116 14 ply. Anyone have experience with those?
06-06-2016, 01:01 PM
You can order the Sailun tires online and have them shipped to you. Check simpletire.com and see if they have what you want in stock.
If there is a Discount tire near you they can order them for you as well.
2015 Chevy 3500HD
2013 Sandpiper 365SAQ
06-06-2016, 03:11 PM
Commercial Member
The Normans
Was your tire a sidewall Run Low Flex Failure or a Tead Separation. Different failures with different causes need different solutions.
Did you read the thread " Why Tires Fail?"
.Write a blog on RV tire application RV Tire Safety. 48 years experience as tire design & forensic engineer. My RV Freelander 23QB on Chevy 4500 chassis. Giving seminars on RV Tire applications (not selling)@ FMCA Conventions. Mar 20-22 Tucson AZ
06-06-2016, 03:28 PM
The Normans
Good year will not cover any damage, they will say either you where under inflated or anything else. Good year used to be good, NOT ANY MORE. I had 3 belts blow in 4 tires about 31/2 years old. I would wait if you can... Good luck.. Marathons IMO are garbage since they moved the production offshore 4 years ago. They will blame you for hitting potholes and curbing and anything else they can think of. PS: not the same tire size but still GY.
Coachmen M/H
Concord
2018 / 300 DSC
06-06-2016, 04:28 PM
OK the young man was inexperienced enough to tell me I could use Goodyear G611s on my Cardinal but it turns out he was misquoting and there is no such thing as a G611. Sailuns on national back order. TowMax (E rated) seems to invite the same problems as I had with the Marathons.
I have a flange sticking out at the front left that most likely hinder the clearance on the G614s but they say they can move the flange out of the way and make the G614s work. Guess I'll know on Friday. I have a replacement Marathon ordered in case it all doesn't work out.
Any other advice or opinion is welcome.
The Normans
06-06-2016, 04:31 PM
Tread separation. Checked the pressures before I got on the road that morning, right at 80 psi.
The Normans
06-06-2016, 06:46 PM
Went to G614's last year after a Marathon blowout. Just check your wheels to make sure they are capable of handling the G614's 110 psi requirement. Mine were stamped/cast on the inside "Max PSI 110". I now feel much better.
P.S. I also purchased a TPMS to monitor psi & temps.👍
2014 Prime Time Sanibel 3250
06-06-2016, 09:44 PM
Commercial Member
The Normans
OK any chance you can post or send a picture?
Did you file complaint with NHTSA?
06-06-2016, 11:08 PM
Look-up the specs for his trailer. 6840# GAWRs with 3420# tires. IMO upgrades are desperately needed.
A Trailer Tire Poster
06-06-2016, 11:30 PM
When we started losing our marathon's, discount tire prorated them because the first tire tread separated while on the spare tire carrier with a plastic cover on. It looked like a twisted donut. He told me as they separate he will prorate.
2019 Ford F-250 6.2l gas 430 E Lock
2015 Cedar Creek 34RL
MORryde IS 7000 LB
Kodiak Disc Brakes
06-07-2016, 02:32 AM
I also run withe Goodyear Gs after having a blowout with my Es. Insurance covered the damage. I was fortunate enough to have G-rated rims. No problems since, about 2 years.
06-07-2016, 03:26 AM
Is he also going to pay for the damage if you don't catch it and stop in time. Did he say how the tire thread separated while on a spare tire carrier by chance. Now that is a true first for me to hear.
Coachmen M/H
Concord
2018 / 300 DSC
06-07-2016, 06:23 AM
Commercial Member
Did you file a complaint form with NHTSA? Until we get the numbers that reflect the current level of performance the lobbyists that oppose any increase in tire capacity & quality will continue to deliver the quality we currently have.
06-07-2016, 06:31 AM
I think that's a normal number. Manufacturers will de-rate an axle to comply with some other limiting factor. In this case the limiting factor is max tire weight rating.
My TT was delivered with axles rated at 5,200 pounds. However, the trailer specs show an max axle weight of 5,040 pounds. Since the factory installed tires are rated at 2,520 each Forest River de-rated the axles to match the number derived from the specifications of the tires.
Going further, assume a manufacturer publishes an axle limit of 6,000 pounds. The axle placard says 7,000 pounds and the tires are 3,800 pounds each. Why did the manufacturer say 6,000? We probably will never know. Maybe they installed cheap mounting bolts that might break with a weight over 6,000. Or, did they position the axle on the frame where more than 6k would cause a problem. We'll probably never know. What I do know is that if I exceed the published number I might cause damage or get hurt. Just because I replaced my tires with E-loads of 2,800+ pounds doesn't mean my axle rating is now higher than the published number. It appears my axle limit should now be 5,200 pounds, but maybe, just maybe, there was another reason FR said 5,040.
Same scenario with my enclosed utility trailer. It has a single axle rated at 4,000 pounds and tires rated at 2,150 pounds each. However, the max trailer weight is published as 2,990 pounds. Why??? That number is used to comply with the max weight limit of 3,000 pounds for a trailer without brakes in the state where it was manufactured.
BIRDS AREN’T REAL
06-07-2016, 07:01 AM
Commercial Member
Going further, assume a manufacturer publishes an axle limit of 6,000 pounds. The axle placard says 7,000 pounds and the tires are 3,800 pounds each. Why did the manufacturer say 6,000? We probably will never know. Maybe they installed cheap mounting bolts that might break with a weight over 6,000. Or, did they position the axle on the frame where more than 6k would cause a problem. We'll probably never know. What I do know is that if I exceed the published number I might cause damage or get hurt. Just because I replaced my tires with E-loads of 2,800+ pounds doesn't mean my axle rating is now higher than the published number. It appears my axle limit should now be 5,200 pounds, but maybe, just maybe, Ther was another reason FR said 5,040.
Oh Nooooooooooooooo
Don't tell me RV mfg are reducing capacity numbers so they can use lower rated components.
06-07-2016, 10:22 AM
The vehicle manufacturer has more reasons than just tires to consider when setting axle ratings to a GAWR. All GAWRs plus the published hitch weight must equal GVWR. Then there is the cargo factor. NHTSA does not allow any fudge factor for the GVWR so all of the other factors are manipulated to provide stable figures to work with. If an owner is worried about tire capabilities they always have the option of reducing the weight of all the STUFF they carry as cargo.
06-07-2016, 10:44 AM
Please change to a G rated tire if your rims will support it. If not please buy new rims and tires that will support the g rated tire pressure.
I realize that it is a big hit to the budget. I realize the Manufacturer SHOULD have enough respect for their customers safety to provide an appropriate tire with a decent safety margin when loaded.
I'm running 16 inch G rated sailuns on my 3825. DW made them swap the marathons at pick-up. After much advice from the members of this forum.Pulled it from South Carolina to Ohio Sunday. Tires preformed as expected with no issues. Would I have wanted to pull it with the E tires. Not on your life. I would have worried the whole time.
Your front bath floorplan is even heavier than my front living. And it will load the tires differently. But for peace of mind find some g rated tires and rims. And file the NTHSA complaint. Tireman9 gives good advice. Listen to him.
2016 F350 6.7 Drw 4.30 gears
2016 Cardinal 3825 FL
2011 Big Country 3500RL...Sold
DW, 2 Spoiled Beagles IZZY and Pup Pup,
And Hillbilly Bob an American Bobtail Rescue Cat.
Seeing America one jobsite at a time..
06-07-2016, 04:54 PM
Commercial Member
What the US RV industry needs is competition from companies that understand real vehicle engineering an build quality.
Detroit got its clock cleaned when Toyota, Honda etc came in with vehicles with good quality.
Maybe the Koreans can come to the US market and do the same for "Elkhart"
Today you can buy cars with 3 - 10 year warranty on various components. You do not have to take your Ford to Dearborn or your Honda to Marysville, OH etc to get a problem fixed. IMO the RV companies are banking on the idea that few owners will use their RV more than 3 months in the first year and if there is a problem then the dealer may simply be too busy to do the work in a reasonable time.
Would you tolerate leaving your car at a dealership for 4 weeks, and have no replacement vehicle offered, while a part is ordered?
The argument that an RV is a House on wheels just doesn't fly. How can every car sold in the US today have at least 3 year coverage on the 12v electric system but you can't more than a few months out of the 12v system in your RV?
Look at the quality of the wiring and connectors. I have seen some parts at Harbor Freight that look better than what I have found hidden behind panels in my motorhomes.
