Old 01-06-2016, 07:41 PM   #11
Rugersdad,
please PM me.
Thank you
Geldevik is offline   Reply With Quote
Old 01-06-2016, 08:39 PM   #12
rugersdad's Avatar
Could not find the PM feature so I will send to email.
rugersdad is offline   Reply With Quote
Old 01-08-2016, 11:28 AM   #13
Ive seen everything up to a Jeep being pulled behind a fiver. If you have a competent fabricator build your hitch you should be fine within reason. Check with your manufacturer they may offer a hitch as an accessory. I wouldn't be concerned about the frame warranty. It's only for one year anyway. JMHO
2015 Chev Silverado 3500 dually D/A
2016 Cedar Creek 36CK
B&W Patriot 18K, Trail-Aire pinbox,
Level up, dual panes & all that stuff...
GOTTOYS is offline   Reply With Quote
Old 01-08-2016, 12:54 PM   #14
bikendan's Avatar
The frame has its own separate warranty.
Usually it's 5 or 6 years.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 01-08-2016, 06:04 PM   #15
I've never seen that. I'm sure Lippert who builds about 90% of the frames has only a one year warranty..
Old 01-11-2016, 12:13 PM   #16
downtime's Avatar
I installed a 2in hitch receiver(custom made n over kill) on my Jaco and will do the same on my Wildcat later in the spring.I pulled all over Ohio as well as several years to Lake D'Arbonne,La.In Ohio as well as most stats that a person can pull doubles you must have breaks all trailers.Cross the chains ect and be sure to pretrip and post trip as well as at any other stop Check your rig out. I carry a bat to check tires and to push the boat back if it comes around and wants to pass me . If you have a school or any large parking lot close by pull in there and practice turns,you'll be surprised at how tight it will turn. I had a peak back up camera on it and will put another one on the Wildcat and have put them on several other fifth wheels as well.
Life is short and none of us are all that Tall !
downtime is offline   Reply With Quote
5th wheel, cardinal, hitch, trailer, wheel
