Old 05-25-2015, 06:28 AM   #1
Truck Specs Question
Looking at a new 2015 Cardinal 3450RL and want to be sure we purchase the right trucks. We do not want a dually!
Would a new F250 Super Duty 6.7 Diesel or GMC HD 6.6 Duramax handle it?
I have no problem going with a F350 if it would be a big improvement over the F250.
Hitch Weight 2260
Dry Weight 13029
Gross Weight 15940
Thanks!
Laynlow is offline   Reply With Quote
Old 05-25-2015, 06:42 AM   #2
acadianbob's Avatar
It's all about the payload capacity of the truck vs the WET hitch/pin weight of the trailer. And don't forget about what you load INTO the truck; like spouse, dog, kids, coolers, generator, etc. That also comes out of payload.
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
Old 05-25-2015, 07:03 AM   #3
mcnabbwr's Avatar
If I remember correctly, based on the Ford RV towing guide the F250 4X4 crew cab, 156" wheelbase the payload is under 2000 lbs with the 6.7l. The F350 is just over 3000 lbs. you may want to check on their web site and verify the numbers, but I believe you will want the F350. I would guess the same holds true with GM.
Bill & Pam
2014 Trilogy 3650RE
2015 F350 PSD
mcnabbwr is offline   Reply With Quote
Old 05-25-2015, 07:55 AM   #4
DDC
DDC's Avatar
The GMC 2500 with std box crew cab srw payload is 2590lbs with a 6.6 duramax, the 3500 is 3890 everything else is the same, there is little difference in the price.
Cedar Creek Silverback 33IK
Donald&Casey cairn terrier
DDC is offline   Reply With Quote
Old 05-25-2015, 08:03 AM   #5
camper1999's Avatar
My 2011 GMC 2500HD Diesel has a payload of 3,100. I am not sure if the newer models are the same
Old 05-25-2015, 08:05 AM   #6
mud yapster's Avatar
If you want a better to I'd get a 1 Ton diesel dually of any brand. I think you will be glad you did specially if you towing in the wind.
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
mud yapster is offline   Reply With Quote
Old 05-25-2015, 08:25 AM   #7
DDC
DDC's Avatar
Only reason I knew this is because I have been exploring this question, I took the numbers from GMC specs sheet, they may have lowered them due to accepting SAE J2807 standards or the ones I was looking at were 4X4.
Old 05-25-2015, 08:39 AM   #8
camper1999's Avatar
The newer number probably are different. Mine is a 4x4 but it also has the plow package, which I do not plow, but it increase the payload a little.
Old 05-25-2015, 08:59 AM   #9
camper1999's Avatar
One of my main considerations when I bought my truck was can I garage it and the ease of parking when not towing. I did not want to buy a $50k truck and have it sit outside. GMC came out with, after my model year, a 3500 Diesel HD with a short bed. It has the extra payload without the size. That out be my truck choice if I bought today
Old 05-25-2015, 10:23 AM   #10
Jim34RL's Avatar
Hitch Weight 2260
Dry Weight 13029
Gross Weight 15940
Thanks!
What is wrong with the highest towing rated vehicle available for 2015 Model Year? The Ram 2500/3500 Cummins equipped truck that meets the SAE J2807 towing standard.
For the 2500 a Crew Cab 4X4 Short box with a 3:42 axle ration and the 68RFE 6-speed auto; the following weights apply. All weights are in Pounds
GVWR 10,000-truck; Payload 2,360; Base weights: Total 7,640; front axle 4,724, rear axle 2,916; GAWR Front 5,750, Rear 6,000, GCWR 25,300, and max trailer weight rating of 17,180.
This is per the Ram Body Builders Guide and the following foot notes apply:
Pay Load and Trailer Weight Rating are Mutually exclusive.
From an engineering standpoint I understand this totally and I have never ever seen where the payload concern has ever been mention by the engineering teams where towing is a concerned. I am a retired heavy vehicle engineer.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 112K+miles
truck
