Old 08-26-2018, 03:59 PM   #1
Telstar's Avatar
Truck tire pressure
Just replaced my 2005 F-350 long bed with a 2018 Ram 3500 short bed. Love the Ram, but the ride is not as smooth as the F-350 was. The door plate says 60 lbs in front and 80 in the rear which is what the F-350 called for as well. I would definitely use those pressure while towing. My question to the group is "What tire pressure do you use when not towing and no load in the bed?" I tried 60 all around and noticed a slight improvement in ride, wondering if 55 or 50 would be acceptable. Thanks for your input.
Gary and Donna
2005 Cardinal 33TS-LX
Trail Air pin box
Center Point suspension
2018 Ram Laramie 3500 6'4" box 2WD
Demco AutoSlide 18k
Telstar is offline   Reply With Quote
Old 08-30-2018, 09:29 PM   #2
Kenz's Avatar
The ride difference may be to some extent due to going from a long box to a short box. Also brand/type of tire may contribute also. The thing with changing tire pressure is that they're weight capacity changes by the amount of air. A tire at 60psi is rated to carry a certain amount of weight. Add or subtract 5psi and the weight capacity changes. So theoretically every time you changed the pressure you need to check the weight. Not very convenient. And the numbers are different from one brand to another.
Thus, long story short, my 2005 ram dually 2wd runs 80psi in all 6 tires, all the time.
2011 Coachmen North Ridge 290RKD 5'er
2005 Dodge quad cab dually diesel 6'spd manual
1 weird cat with an occasional attitude problem.
Kenz is offline   Reply With Quote
Old 09-02-2018, 07:26 AM   #3
The short bed does ride a little harsh, I have a long bed Silverado that says 60 front 80 rear. I run 60 all around when not towing, it makes for a softer ride besides I donít haul anything in the bed but the hitch
spock123 is offline   Reply With Quote
Old 09-02-2018, 08:12 AM   #4
onetonford's Avatar
On my F-350 cc long bed dually it shows 60 in all tires.
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
onetonford is offline   Reply With Quote
Old 09-02-2018, 10:21 AM   #5
Jim34RL's Avatar
Will my short bed truck rides better than a long bed regular cab truck for my model year, 2008. Just to make a point, it is not the bed length but the wheel base that matters for ride comfort.
When using my stock tires and rims in the winter months, not towing the rear tires are set at 45PSI and the front tires are set at 60 PSI. This provides for my truck the best ride.
Experiment on your truck and tires to see what is the best ride comfort for you. Also rub chalk all over the rear tire from side wall to side wall at different air pressures settings to see if the truck tire is cupping or not at these different tire pressures. This way you will determine what is best for you.
Jim W.
2016 34RL CC; 2008 Ram Mega Cab 2500HD, 6.7L, 68RFE 6 speed, 4X4, Smarty S67, TDR 135K+miles
Old 09-02-2018, 10:36 AM   #6
Professional Curmudgeon
wrvond's Avatar
According to my owner's manual and the tire safety data plate on the driver's door frame, my fronts are to be set at 70 psi while the four rears are set at 65 psi always - loaded or unloaded makes no difference.
What does your owner's manual and data plate say?
2014 Coachmen Catalina 253RKS
2017 F350 6.7L DRW CC LB 4x4 Lariat
wrvond is offline   Reply With Quote
pressure, tire, truck
