Old 01-27-2016, 10:54 PM   #21
Originally Posted by dieselguy View Post
For the repliers that think the Goodyear Marabomb failures are vastly overstated ... perhaps true if you tote around a 6000 - 7000# RV. For those of us that pull in the 12K+ range, they are a nightmare waiting to happen as these tires are just not up to the load ... period. I got rid of mine on my own dime as peace of mind is priceless. Mine SOB (12K+) Marabombs had bumps, bulges, and tread separation within 4000 miles and I religiously checked air pressure, axle weight, and kept road speed 65 and under. I've had dozens of acquaintances in my Keystone days that had fiver damage due to Marabomb tires failing in multiple ways. Some refused delivery until an alternate tire was swapped out. Several went with G614's ... I was light enough to go with Michelin LT tires. The old Marabombs went to tire graveyards or were sold to farmers who use them on their slow moving implement trailers used around the farm. I know I'm just blowing hot air in many of your minds, but with the heavier RV's you're definitely living on borrowed time running the Marabombs. There's to many of us to simply discount the issue.
X2!
918jeeper is offline   Reply With Quote
Old 01-28-2016, 12:26 AM   #22
mlwilliams808's Avatar
I had the goodyear marathons as OEM and 3 of them failed in under 5500 miles, I am anal about weight & check tire pressures every day while travelling. I bought 14ply Samson G rated and haven't had a problem so far in 11,000 miles. I sent the tires back to goodyear factory through a dealer and haven't heard a word back in 3 months. The failures were wild wires in tread and sidewalls.
2015 Blue Ridge 3025RL
2015 Ford F-250 4X4
Miles logged: 45,000
mlwilliams808 is offline   Reply With Quote
Old 01-28-2016, 12:46 AM   #23
Originally Posted by Walking thunder View Post
Today, 07:16 PM
Not sure if I should start a new topic but I'm having issues with Forest River and Goodyear regarding the OEM China bombs on my 2015 Cardial 3580 RL
GAW 6840. Tires: Marathon ST235/80r16
My rims will handle the pressure of an ST235/85r16 like the good year G614
I very familiar with the concept of weight/ correct psi etc. I also understand that not all of the GVW is on the axels a portion going to the truck/hitch
I have attempted with no luck trying to get my warranty rep from Forest Ruver or Goodyear to understand that I truly don't want the hassle,,,,expense ,,,,or even worse possible injury due to a blow out on the crappy marathons that it came with.
Tires have ALWAYS been at correct pressure and veh was weighed to include end axel weight and has ALWAYS been under gross.
I'm curious how many of the China bomb blowouts have happened with correct settings?
My rep from the factory tried to get me to believe that the percentage of this tire on the road that have had issues is low. What do you all think? He even went so far to say that the forums are just full of complainers.
I looked at the Ceder Creek version of my 5er. Everything the same on the federal sticker EXCEPT THE FOLLOWING
Now they have gone to true 7000lb axels and have the G614 St235/85r16.
This would lead me to believe that they found there was a problem and so the newer models have the better axel. Also the GVW of the Ceder Creek was little over 200lb more than my Cardinal.
I would be more than happy to pay the difference for the better tires. My marathons only have 2 short trips on them. Am I making a mountain out of a mole hill? Do I spend big money on new tires even though mine a pretty much new?
I am running Marathons on our 28RKS TT with no issues. Our trailer grosses 9200LB loaded to go. Last summer we put on 14000KM (Almost 2000 of it on gravel) with NO problems. I'm very careful with tire pressure but other than that use them as they were meant to be and no issues. I've been a Goodyear fan my entire life and have no issues.
Floyd & Carolyn
2012 F150 S/crew 4X4 6.2L 6Spd Tow Max Firestone airbags.
2011 28RKS Wildcat. Yamaha 3000iseb Generator.
2013 22 nights.2014 57 nights.2015 116 nights +14300KM
2016. 96 nights
Filterman is offline   Reply With Quote
Old 01-28-2016, 12:51 AM   #24
I honestly do believe that the number of tire issues is vastly low compared to the number of people who complain about them.
I think that using forums as a gauge of normalcy vs. problems is a skewed universe. People often come to problems solely because they have issues (though, I wouldn't call them complainers).
Totally agree or folks have unreal expectations of tires , equipment etc. I read these forums and thing I must have horseshoes in all the right places or have a superbly manufactured unit!!
Floyd & Carolyn
2016. 96 nights
Old 01-28-2016, 10:59 AM   #25
Tires
Someone asked about Duro. I had two fail last year on a trip from Washington State to Omaha and back. I caught the first before it completely failed, however the second blew and cost me several thousand in repair costs.
When I put the Duros on I upgraded from load range E to F.
I was keeping my speed below 65 on a 80 MPH highway (you can imagine how the truckers felt about me) and I had the installers recommended air pressures and I was stopping about every hour to check my tires. And yes, I have weighed my trailer and all that stuff.
My experience with Duro to get some sort of compensation for even acknowledgement of a problem was unsuccessful.
Then to top it off the wholesaler went out of business and another company picked up the brand. At that point they would not even talk to me.
Any way, my experience shows me that the Duros aren't any better than the others.
I purchased a tire monitor so that if I loose another tire hopefully the monitor will let me know before any damage occurs.
Broncl is offline   Reply With Quote
Old 01-28-2016, 11:58 AM   #26
Thanks Broncl
That helps me make a decision on the Duro tires. With all due respect to everyone & their opinion on tires, it seems as though there are really not any tires out there for our RV's that we can put a whole lot of confidence in. Some say a certain brand is great while others say it is junk. Some will say one is junk & yet another will say it is great. I have read every thread pertaining to tires & it is the same as any other topic; it all comes down to personal preference & hope for the best.
Good luck to everyone with these tire issues & be safe.
Papa GLS is offline   Reply With Quote
Old 01-28-2016, 01:06 PM   #27
I had Duro 2100 radials OEM for 4 years and 9000 miles. They were great tires. Held air all year long. Now I have Hercules Power STR for two years and over 12,000 miles. Has also been a great tire although they lose a few lbs twice a year.
2010 F250 5.4L 3.73
2011 Flagstaff 831FKBSS
Equal-i-zer 4pt 12K
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
lbrjet is online now   Reply With Quote
Old 01-28-2016, 06:20 PM   #28
Thanks for the info lbrjet. Just proves my point in my previous post. I think I'll stick with my OEM's until they need to be replaced & then????????????.
Old 01-28-2016, 06:40 PM   #29
caper's Avatar
People are calling the OEM tires china bombs. What they do not know is how the tires were treated while being delivered. Was the air pressure low, did the driver hit a lot of pot holes on the highway, what speed were they driving. All these situations are unknown. How would the higher priced tires hold up if were put on at the factory and delivered?
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 01-31-2016, 11:29 AM   #30
rugersdad's Avatar
I removed my E rated Marathons shortly after I got my camper and installed SOB G rated tires. Had one blow out after 2000 miles. Put on the spare got to my campsite and ordered 17.5 wheels and tires and installed them before I left. My Cardinal has 7k axles from the factory. It's an expensive upgrade but well worth it considering the damage a blown tire can do to your camper.
rugersdad is offline   Reply With Quote
