Old 01-20-2015, 03:59 PM   #1
Valve, size 1&1/2" or 3 inch waste water size
Hello,
On our 2008 Cardinal we have 3 waste water valves, black water from toilet, grey water from toilet and grey from kitchen. One or all are leaking since when I setup and pull the cap I get some flow. Looking on replacements I find 1&1/2 as well as 3 inch.
I'm thinking grey's are 1&1/2 and black is 3" would that be correct?? Which would I have?
2008 Cardinal 30RK fiver.
2009 Chevrolet 2500HD DuroMax
2009- 42 days; 2010-40 days, 2011- 40 days. 2012- 30 days,
2013- 14 days, 2014- 21 days, 2015- 42 days
2016-17 days, 2017-zero days
Wanderer is offline   Reply With Quote
Old 03-25-2015, 07:01 PM   #2
You are correct regarding the pipe sizes. I have a 2007 and had the same problem. The easy fix is to purchase an external valve that connects directly to your drain outlet. This valve will provide additional protection against spills. If the problem becomes worse, you can always replace the offending valve.
2007 Cardinal 30T
2004 Chev Duramax 2500HD
B3KEYS is offline   Reply With Quote
water
